Results 1 to 3 of 3
    Fomula with Shimano disc
    Any one using the formula B4 pro with shimano rotor?
    Or should I just get a adapter to convert my hub to 6 bolt?
    How thick is the Shimano rotor?
    Formula rotors are only 1.8 mm thick. If Shimano are 2.0 mm, you may have clearance issues with new pads. Also, is your B4SL 140 mm rear? Does Shimano make a 140 mm rotor?
    PS. If you decide you'd rather just sell your Formulas, I'll take them!
    should be no problem, just push the pads back in further
    brakemeister
  1. New to the sport, need bike :)
    By iLLestOne in forum Bike and Frame discussion
    Last Post: 05-13-2005, 06:28 AM
  2. Xc ~$1500
    By ontologist in forum Bike and Frame discussion
    Last Post: 03-16-2005, 12:33 PM
  3. Brodie Hellion vs. Specialized Rockhopper
    By Charlie in forum Bike and Frame discussion
    Last Post: 02-06-2005, 08:03 PM
  4. Shimano 765 disc adjusting
    By Angry Dad in forum Brake Time
    Last Post: 11-04-2004, 07:18 PM
  5. Maintenance on mechanical disc brakes? Shimano 475
    By Verruckt in forum Brake Time
    Last Post: 08-07-2004, 12:16 AM
