Results 1 to 1 of 1
Thread: Finally!!
    Feb 2012
    Finally!!
    I have finally fixed the annoying death sound that occurred when using my rear Tektro disc brake and it's entirely thanks to this forum I simply installed two washers on the caliper which moved the brake pads out and away from the middle "spider web section of the rotors. Now the sound is what I would normally expect and very faint. I expect that if I upgraded the rotors it would be gone entirely. I previously attempted to work this out with my LBS and would get the usual "that's just physics...that's normal." probably because I am a noob but whatever. It wasn't "normal" and I again thank you guys for continually updating this forum with your experiences and knowledge! Pic attached.
    Attached Thumbnails Attached Thumbnails Finally!!-imageuploadedbytapatalk1331167262.299906.jpg
