Results 1 to 5 of 5
    Faster it.
    Reputation: Raine's Avatar
    Is this enough fluid? (Avid CR)
    Going to swap out my stock brake lines for Jagwire HyFlow front/rear, was wondering if I get this:
    Pro Bleed Kit | SRAM
    So the little container of brake fluid included, is that enough for a fresh install? I'm not sure because it's a "bleed kit," if it only comes with enough fluid to do a bleed - or if it can fill up AND bleed a pair of new, dry brake lines?
    I would think so. Even though the term "bleed" is used, the procedure is essentially replacing the volume of brake fluid in the system.
    Reputation: s0ckeyeus's Avatar
    There should be plenty. I bled and rebled both brakes the first time I used the kit and still had some left over.
    Faster it.
    cool guys, thanks =)
    Even if you flush all the old fluid, you'll have enough new fluid for 2+ sets of brakes. They use a very small amount of fluid to function.
