Results 1 to 7 of 7
    elixir questions.
    I'm getting new avid elixir cr's tomorry and I have a question. Assuming I'll have to trim down the lines and bleed them a little; i remember reading somewher that on these brakes, when bleeding, the pad contact adjuster should be turned either all the way clockwise or all the way counterclockwise, but I disrememer which. So is this true, and if so, which is it? thanks. Also, do they come stock with metallic or organic pads? I'm, hoping metallic. Thanks.
    One Gear
    Reputation: .40AET's Avatar
    Dude...
    Reputation: ebry74's Avatar
    The sram site has instructions. They come with metallic. They're great brakes!
    Reputation: wyrm's Avatar
    On this brake... the pad contact has no affect on the reservoir size, therefore no affect on the pad contact. So you can bleed without having to dink with that.
    Bikeless Rider
    Reputation: cort's Avatar
    Quote Originally Posted by wyrm
    Sorry, your incorrect. Take a look at the vid, or re-read the manual
    http://www.sram.com/_media/techdocs/95-5015-019-000.pdf
    Reputation: Black_Aypim's Avatar
    The elixirs CR don't have auto pad wear adjustment or it's just me?
    ...idios...
    Reputation: SteveUK's Avatar
    "The elixirs CR don't have auto pad wear adjustment or it's just me?"
    It's just you. All hydraulic brakes adjust automatically as the pads wear.
    Diogenes
