Results 1 to 9 of 9
    Reputation: jkad's Avatar
    Dec 2005
    Elixir on a Pike..need help
    Just up graded to Elixir R's ( i know lots of folks hate em) putting them on my Pike fork, my question is do i need spacers between the adapter and the caliper? it doesnt seem to fit without them. If anyone has a pike, can u snap a pic for me? thanks in advance
    Joe
    "foot to pedal, wheel to dirt, there is no substitute for the act of riding "
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    It has nothing to do with what fork you have. Is you pike post mount? Did you get rotors with your brakes?
    Dec 2005
    yes post mount..and now that im looking at it, the new rotor is 180mm...
    B A N N E D
    Most Avid brake callipers need the CPS / Tri Align washers between the calliper and the adapter.
    Without them the calliper won't be packed out enough.
    * The same applies to post mounts and post mount adapters.
    Reputation: mitzikatzi's Avatar
    Do you need one of these?
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Paste eater
    Mar 2006
    Quote Originally Posted by jkad View Post
    I'm' not sure you can even put a 180mm rotor on a pike? That, you probably don't need a rotor that big - at least not on a pike...
    Dec 2005
    Quote Originally Posted by mitzikatzi View Post
    YUP..the pike has a special adapter and it looks like you need to align washers between the calliper . looks like problem solved, thanks for the assistance.
    And FYI the pike is an AM fork, many people run 180mm or even 203mm on that fork
    Paste eater
    Mar 2006
    I had a pike for years. It's a great fork, it's just not that big. However, I'm sure you can put a 180mm on it - I was thinking 203mm.
    Quote Originally Posted by cobba View Post
    that brings back nightmares
