    Elixir 9 seized up
    About a mile into my ride the front piston seized up took the pads out, re-set it, happened again. Then my rear piston seized up a mile later. Is there anything I can do or should I just send em back under the warranty and get new ones? I have only had the bike just under two months. Thanks.
    Industry Vet
    I've worked on many an Avid brake and usually what happens is the dot fluid causes the seals to swell and jam them up. First answer these questions and I will see if i can help. How old are they and have they been bled ever?
    They are about less then two months old. Came on my new Santa Cruz and as far as I know they were pre-bled.
    Industry Vet
    Well no telling how long they sat in a warehouse. I'd completely flush them and lube the pistons to start. Hopefully that helps
