    Nov 2012
    From Elixir 7 to Hope Tech X2.... Rotors?
    That's it really.
    I have 180s up front and 160s rear. The literature I have seen talks about 183 rotors.
    Will I need to replace the front rotor, or does the 180 work? If anyone can help it appreciated.
    These are going on a Kona Kahuna that has a Manitou Tower Pro up front.
    I just want to get whatever I need ordered ASAP, so I am not crippling the bike till I get it all. I hosed my 7s trying to swap out the external adjuster... Had the carbon levers nd no extractor. Wasn't fun. I believe they also sent the wrong kit - for XX not XO. I think the XO kit may have worked, but that's moot at this point. The Hopes are what I am going with, they are on the way!
    Thanks folks!!
    If you use Hope Step-up mount 'F' for 160mm rear on the front it will work perfectly with 180mm rotor. So you need 2 Hope 'F' mounts for your current rotors.
    OOh no!!! Manitou is post mount yes? Not sure about that one. Try North Shore Billet mounts...
    Nov 2012
    unnnnnnnhhhh....
    Nothin's ever easy is it? Yep - the Manitou is a post mount.... i am e-mailing Hope Tech!
    Thanks. I wish I had a local Hope dealer with stock on hand! Most i have called don't do a lot with Hope, its a "i'll order it for you" type thing. Understandable, as they aren't cheap.
