Results 1 to 6 of 6
Thread: Elixir 3R issue
    ITL
    ITL is offline
    Reputation: ITL's Avatar
    Nov 2012
    Elixir 3R issue
    I have a 2013 Specialized Camber Comp with Avid Elixir 3R's on it. I have a strange problem with the rear brake. Sometimes, not every time, when I grab the brake lever it goes all the way to the bar. At other times it functions normally. When it does go all the way to the bar, I find that I can"pump" the brake lever and restore more normal function and regain that firm lever feel. I was looking around the net because somewhere out there I thought I read of a similar problem, and I thought the issues was a faulty seal. Anybody out there know?
    Oct 2012
    I had that happen once on my Elixirs. The pads were worn out completely and I guess the master cylinder was gulping air. New pads fixed it and it's been fine ever since. Didn't have to bleed either.
    If that's not it you are probably low on fluid. It's quite possible that there might not have been enough fluid installed at the factory; Avid has had its problems with factory bleeds in the past.
    Never trust a fart
    Reputation: frdfandc's Avatar
    Need to bleed the brakes. The factory bleed that SRAM puts on them sometimes isn't good enough.
    ITL
    ITL is offline
    Nov 2012
    I'll try to re-bled them and see if that helps. Pads should be OK, but I'll check as well.
    Reputation: Bob12676's Avatar
    I have a rear Elixir 5 that was replaced under warranty twice that had the same issue. The final set, that I am still riding, had the same problem as the first 2 when I first got it. The cure was a very extensive bleeding which took almost an hour. Good luck
    ITL
    ITL is offline
    Nov 2012
    Thank you Bob. Your story is what I had heard, replacements from the factory were still having the same problem and I knew there was an apparent fix, but I didn't know what that was.
  1. Avid Elixir issue
    By SoFlaBiker in forum Brake Time
    Last Post: 09-12-2012, 08:22 AM
  2. Another Elixir 3 issue
    By ZmyDust in forum Brake Time
    Last Post: 05-08-2012, 05:48 PM
  3. New Elixir 5 brake issue
    By jpk1080 in forum Brake Time
    Last Post: 10-29-2011, 02:14 PM
  4. LBS elixir bleed issue
    By Let's Ride in forum Brake Time
    Last Post: 07-11-2011, 03:02 PM
  5. Elixir piston issue?
    By Wish I Were Riding in forum Brake Time
    Last Post: 06-06-2011, 10:39 AM
