    elixir 3 self-adjustment too tight
    I was replacing the oil in the lowers of my fork last night, and while the wheel was off, of course I squeezed the lever on my front elixir 3.
    Should be no problem, I just took a clean butter knife and worked the pads apart until the pistons were out all the way (with pads still installed).
    When I put the wheel back in, I pump the lever a few times and the pads self-adjust to a point where they are closer to the rotor than in the past. It's rideable, but not ideal.
    The only thing I've noticed that seems a little funny is that when I'm squeezing the lever, it doesn't always come back out all the way on its own. I can push the lever out with my hand, but it won't do it on its own.
    Does this sound like a sticky piston or something else? The brakes are about 5mo old, and have been working perfectly until now, so I'm hoping I can avoid bleeding them. The lever isn't mushy so I think there is no air in the system.
    Any help is appreciated!
    Reputation: Shalom's Avatar
    Nov 2008
    Sounds like you possibly got a bit of air into the system when you squeezed the lever with the wheel out. My vote would be for a bleed. If that doesn't work, then maybe dismantle the caliper and ensure that the seals have not been damaged/pinched when the pistons extended without the rotor between them. If so, new seals may be required.
    I appreciate your response, and when I got home from work today, I was pleased to find that for no apparent reason, everything's back to normal.
    But generally, am I mistaken to think that the primary symptom of air in a hydraulic line is mushly lever feel? I didn't think the introduction of air could possibly make the lever feel more rigid.
    The only explanation other than a stuck piston that I can imagine is that when I had the bike tilted 90 deg forward, such that my recon's stanchions were parallel to the ground (so oil didn't leak out as I reinstalled the lowers [29er recon]), something funny happened. But whatever it was, it went away after the bike sat overnight on two wheels.
    Nov 2008
    Quote Originally Posted by PretendGentleman View Post
    Primarily, yes. But I have experienced some odd things. I had one lever go crazy solid. Bled the brake and got quite a bit of air. Not sure what happened, or whether it was a result of the air or something else. It can be difficult to diagnose, sometimes.
    However, great that everything is back to normal. Enjoy riding!
  1. Elixir CR reach adjustment not working
    By mrankin in forum Brake Time
    Last Post: 12-30-2011, 10:40 PM
  2. Elixir CR pad adjustment question
    By notyal in forum Brake Time
    Last Post: 03-22-2011, 07:41 AM
  3. Avid Elixir R SL Pad adjustment
    By nicoswit in forum Brake Time
    Last Post: 03-14-2011, 04:08 PM
  4. Avid Elixir brake adjustment
    By rakerdeal in forum Specialized
    Last Post: 01-23-2011, 05:58 AM
  5. Pad adjustment on Elixir CR?
    By 11 Bravo in forum Brake Time
    Last Post: 09-29-2009, 09:52 PM
