Results 1 to 3 of 3
    Elixer Bleed Question
    First time doing system bleed. On the front I followed directions and no problems.
    On the rear i neglected to fully screw out the pad contact adjuster before bleed. Should I re bleed system or not ?
    I'm not sure of the effect of not screwing out pad contact. Initially i thought I would just see how the brake performs but should I re bleed following proper procedure ?
    Reputation: RustyIron's Avatar
    It will be fine.
    Quote Originally Posted by RustyIron View Post
    It will be fine.
    Thanks. Wanting to do it correctly I opted to re bleed before I saw your post. Had a moment of terror. I was bleeding the caliper and suddenly fluid all over the floor. Yup,
    I forgot to put in the bleed block ! Caliper came out of place. Got a bit worried but placed it back in place, pressed in with wooden paint stirrer and finished bleed.
    Good to go ! New experience and learned alot.
    Again, appreciate your reply.
    DRJ
  1. Elixer question
    By telemike in forum Brake Time
    Last Post: 03-28-2013, 06:50 PM
  2. What am I missing (bleed question)
    By FujNoob in forum Brake Time
    Last Post: 10-19-2012, 05:27 AM
  3. Bleed tool question.
    By Juanmoretime in forum Brake Time
    Last Post: 08-20-2012, 07:49 AM
  4. Avid bleed question(bleed block)
    By Kawigreen99 in forum Brake Time
    Last Post: 02-29-2012, 05:33 PM
  5. Avid Bleed Question
    By ep3w in forum Brake Time
    Last Post: 07-11-2011, 01:06 PM
