Results 1 to 30 of 30
    btx
    btx is offline
    Elixer 5 to SLX swap -- help a chump
    I usually don't touch my brakes...too likely to hurt me if I mess it up, so I leave it to the pros. I have a Giant Anthem X 29er with Elixer 5's. Having gone thru several shops, I haven't been able to get a bleed that lasts more than five or six rides. Having read all the hate in here for Elixers, I'm thinking of just giving up and getting some SLX.
    The Anthem has rotors: [F] 185mm [R] 160mm. 185 is kind of a weird size, right? I'm assuming that means I need to replace it with a 180 rotor? Is it bad to replace only the front rotor?
    I'm looking at the M675 SLX brakes at blue sky.
    BlueSkyCycling.com - Shimano SLX M675 IceTech Disc Brake w/ Adapter
    What is the difference between 51/74mm compatible, I.S adapter and post adapter? What do I want?
    Lastly, is this a nightmare install, should I consider having someone install them?
    thanks for the advice.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I believe you can use the Avid adapter up front with the SLX caliper. That's what I did on my wife's bike. That way, you should be able to use the 185mm rotor.
    In case I'm wrong and it doesn't work, go ahead and swap the rotor for a 180. It won't matter at all that you re used the rear one.
    I like turtles
    turtles make me hot
    And you should be able to do this.
    I like turtles
    Reputation: bigkat273's Avatar
    Re: Elixer 5 to SLX swap -- help a chump
    Shimanos work with avid adaptors. Plug and play.
    Here is the thing about equality, everyone's equal when they're dead. - Gavroche, Les Misérables
    What a screamin' deal on the slx brakes! I just changed out my elixir 7's for xt. I read too much misinformation regarding cross compatibility, do i bought all new adapters and rotors. The ice tech rotors are definitely thicker than avid rotors. Easy install. They cone with spare olive and fitting to cut line shorter if needed. No need to bleed after cutting. Make sure it's clean and straight cut.
    Sent from my MB865 using Tapatalk 4 Beta
    btx
    btx is offline
    So, at least on the one side they had three different options for adapters. Even if it doesn't matter, is there a better choice there between:
    I don't really know what any of those mean
    Reputation: Joules's Avatar
    Quote Originally Posted by btx View Post
    51mm and IS are the same thing, the older type of mount where the bolts are parallel to the axle.
    74mm and PM (post mount) are the same. This is more common on newer forks, where the bolts thread into the fork leg.
    Your fork determines which adapter you need.
    If you get a pre-bled setup with the Shimano brakes, install is easy with no real need for a shop to do it.
    Also, somone correct me if I'm wrong, but isn't the oddball 185 the result of the CPS washers spacing the caliper out on the adapter. Not sure if that's relevant or not (like could you use a shimano adapter/caliper with the CPS washers and a 185mm rotor).
    btx
    btx is offline
    Quote Originally Posted by Joules View Post
    Unfortunately, the bike isn't with me at the moment to look at the adapter that came with it and the Elixers. The fork is a Fox F29 RL, so that means I should buy the "180mm Post mount front".
    Any recommendation on inexpensive rotors? My other option is to just buy new rotors (for an XC bike and what I've read, those ice techs look like overkill to me?) -- that way I could include the rotors when I craigslist the elixirs...also an option.
    Thanks for the help!
    turtles make me hot
    You already have the correct adapter. Just put the Shimano caliper on the Avid adapter.
    I used Avid Clean Sweep rotors with the Shimano brakes. It works perfectly.
    I like turtles
    btx
    btx is offline
    ...ordered! Thanks for the help!
    Reputation: joel63's Avatar
    May 2012
    I swapped out the Elixir 5 brakes for SLX on my Yeti before it left the bike shop. Tried it first with the Avid rotors, can't remember the part number but they were the wavy ones. Had the dreaded turkey warble noise from day one. Scuffed with grey scotch brite pad and cleaned the rotors, it went away for awhile but came back. Did that twice and decided they had to go. Swapped out for Shimano Ice Tec, no bad noises and drastic improvement in stopping power.
    turtles make me hot
    Quote Originally Posted by joel63 View Post
    Wow, really? Good to know.
    I like turtles
    May 2012
    Quote Originally Posted by NYrr496 View Post
    Yep, granted, it wasn't horrible loud the first 25 miles or so and was intermittent,but got louder and more constant each ride.
    Is the price on bluesky (brakes) for both front and rear or each?
    turtles make me hot
    Each.
    I got a couple of sets from some Ebay seller in Hong Kong. 195 for front and rear with brackets and hardware. No rotors.
    I like turtles
    Reputation: SlowMTBer's Avatar
    Dec 2011
    I swapped mine out from Elixer 5 to XT (same mounting as SLX) and with my 185mm rotors, the Avid adapter DID NOT WORK. Mine are the Post Mount. Some people have said that their Avid adapter worked, and that may be the case, but not if it was the same as mine. Once I obtained the correct bracket, it didn't clear the 185 rotor. I had to make shims to space the Caliper further away from the fork leg posts, to clear the extra 5mm of rotor diameter.
    Hopefully yours is one of the ones that work, but just make sure that when you put the adapter and caliper onto the post mount fork, everything fits together squarely. The Shimano should use bolts and flat washers, not the cupped washers used to adjust the positioning of the Avids.
    2011 Trek Rumblefish 1
    Reputation: Rock's Avatar
    I'm in almost in the same boat here. I'm changing from Elixer 5 to Shimano M596 for my 2013 Enduro. I'm having a hell of a time finding the rear shimano adapter for a 180mm p/p. The front 200 p/p is no problem. I have the Shimano rotor (180) and apparently my Avid Rotor is 180 now. Does anyone have a source for this adapter?
    How can anyone who's been riding as long as I have, be so slow???
    B A N N E D
    Quote Originally Posted by Rock View Post
    I'm having a hell of a time finding the rear shimano adapter for a 180mm p/p. Does anyone have a source for this adapter?
    If you have 160mm post mounts on the rear then a 180mm front PM to PM adapter is what you'll need, it'll work on the rear the same way it works on a fork with 160mm post mounts.
    160mm post mounts = mounting a brake caliper directly on the post mounts when using a 160mm rotor.
    It shouldn't be too hard to find one of these adapters.
    If you look at the dimensions of 160mm front post mounts and 160mm rear post mounts you'll see that they are the same.
    http://www.hayesdiscbrake.com/wp-con...10722-1_RA.pdf
    http://www.hayesdiscbrake.com/wp-con...10722-9_RA.pdf
    Quote Originally Posted by cobba View Post
    Cool. Great Info. I guess it makes sense since these are basically "spacers" with the direct post mounting method.
    Thanks.
    btx
    btx is offline
    So, I got the kit, and I have run into some problems.
    1) The avid adapter feels nice and secure, but there is a bit of a gap because it doesn't sit exactly flush on the brake (image attached). Is this acceptable or a reason to switch to 180 in the front?
    2) The cable is actually a few inches shorter than the avid that was on it before. It feels kind of borderline (I suspect the old one is 1700 vs the 1400 this came with, didn't really consider this at order time). It might be hard to tell based on the image, but is this acceptable or is should I go hunt for a longer cable?
    3) I've had a hell of a time getting the calipers centered. In the past with the various Avid's I've had, I would loosen the bolts, strap the brake lever in and then tighten. This doesn't seem to work for the shimanos (I don't think my rotors are warped, if they are, I can't see it with my eyes and rub wasn't much of a problem on the elixirs -- still replacing the rotors is certainly an option here)...
    thanks!
    Elixer 5 to SLX swap -- help a chump-cable.jpgElixer 5 to SLX swap -- help a chump-front_brake.jpg
    turtles make me hot
    Are you able to turn the wheel or is the caliper bottomed on the rotor? That certainly doesn't look right.
    I like turtles
    btx
    btx is offline
    Yup, wheel turns. Lots of rub though -- it isn't spinning free.
    turtles make me hot
    It isn't right for sure. That's a 185 rotor, right? Either space the caliper or try a 180.
    I like turtles
    btx
    btx is offline
    Yup, it's a 185 with a 185 avid adapter. Do you have a suggestion as to what I should use as a spacer? I can't space it by much with the bolts it shipped with.
    Feb 2013
    Have you tried rotating the adapter 180 degrees?
    btx
    btx is offline
    It has an arrow indicating the up direction, it was like that before too. I did, however, just realize that the old system had a CPS washer between the caliper and the adapter. It had longer bolts too.
    It was like this:
    post --> adapter --> [( caliper )] --> thin regular washer --> bolt
    Is it a bad idea to use the cps washer as a spacer with the old (longer) bolts?
    Feb 2013
    It was just a guess but if it's indicated I'm sure you have it right. I thought the purpose of the cupped washers was to allow alignment of the caliper. If so shouldn't it be between the adapter and the caliper body?
    btx
    btx is offline
    Shimano manual shows it only between the caliper and the head of the bolt.
    B A N N E D
    It was like this:
    You could double stack the CPS washers if you wanted, I see no reason why you couldn't.
    post - adapter - caliper - CPS - CPS - thin regular washer - bolt
    B A N N E D
    Quote Originally Posted by willembad View Post
    Shimano brakes don't need the extra spacing that the CPS washers would provide if put between the caliper and the adapter or between the caliper and the post mount.
    If you were to put the CPS washers between the caliper and the adapter or between the caliper and the post mount with a Shimano brake then the brake pads would overhang the rotor.
  1. Elixer question
    By telemike in forum Brake Time
    Last Post: 03-28-2013, 06:50 PM
  2. Upgrade Elixer 5 to SLX or XT
    By stygz1 in forum Brake Time
    Last Post: 11-25-2012, 09:39 PM
  3. Replies: 7
    Last Post: 11-07-2012, 08:05 AM
  4. Elixer 5 Problem
    By D-Avid in forum Brake Time
    Last Post: 04-28-2011, 12:11 PM
  5. Wheel Swap... Chain Swap Too?
    By coopdad in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2011, 05:49 AM
