Results 1 to 6 of 6
    Reputation: Sparkyrad's Avatar
    Feb 2005
    El Camino Squeal
    I have been riding a set of El Caminos on my new Intense Uzzi Vpx and the rear set squeals and squeals. I have tried adjusting them with the power know on the lever, but that doesn't help. They sometimes squeal even when I am just riding along and not applying any pressure to them? I had them installed at my LBS. Any suggestions would be helpful. Thanks!
    nnn
    nnn is offline
    Reputation: nnn's Avatar
    Feb 2005
    You will most likely need to face the brake tabs.
    Race Technician
    Reputation: Randy@Hayes's Avatar
    Jan 2005
    Alignment?
    Sounds like the pads were not aligned on the disc very well if they make noise without squeezing the lever. I'd take them back to the shop and have them align them again. If the rear mount is not perpendicular with the axel the pads are not contacting the disc at the same time. That is a frame issue. Contact the frame manufacturer.
    Randy
    Feb 2005
    Thanks Randy!
    Randy - it was the alignment. It must have come loose after the initial set up. Now they run great. They are awesome brakes! Thanks!
    Feb 2005
    Randy - US Nationals/Tech Support?
    Randy - Will the Hayes Race rig be at the US National in NJ over Memorial Day? I would love to have you guys set up my brakes as my LBS is just a Mom and Pop store who are not great with High End gear.
    Also - can I send you a self addressed stamped envelope to get some Hayes and
    El Camino stickers?
    Race Technician
    Jan 2005
    Yup...
    Yes, We'll be there. Stop by and say hi. Stickers? Yes, send an email to our tech address, hayestech@hayesbrake.com.
    Glad I could help.
    Cheers,
    Randy
  1. hayes El Camino Vs shimano Deore ?
    By Picard in forum Brake Time
    Last Post: 04-16-2005, 09:44 AM
  2. Juicy 7 - El Camino - Mono Mini - which one ?
    By caballero in forum Brake Time
    Last Post: 03-29-2005, 09:11 AM
  3. Advantage of Hayes El Camino vs Mags?
    By Blaster1200 in forum Brake Time
    Last Post: 03-24-2005, 03:59 PM
  4. Disc: El Camino or AVID?
    By Pelly_NH in forum Downhill - Freeride
    Last Post: 03-22-2005, 12:24 PM
  5. Hayes El Camino - Avid patent infringement?
    By r1Gel in forum Brake Time
    Last Post: 10-09-2004, 03:23 PM
