Results 1 to 6 of 6
    Beer Me!
    Reputation: Guerdonian's Avatar
    Easy Question (I think), oil got on XT Icetech Rotor.
    While bleeding my shimano XT 785's this weekend I somehow unknowingly got some oil onto the rotor or pads on the rear brake and ruined the braking performance.
    I plan on replacing the pads of course as they are dead, but what should I do with the rotor? Will cleaning it with Simplegreen work? is there anything funky with the Icetech stuff that I should know about?
    "Any wheel size is better than sitting at a computer all day." -Myself
    clean rotor with Rubbing alcohol. Easy.
    Break pads, if oil is on em are toast most likely, i would replace em.
    Lynn Woods
    JRA cycles
    Beer Me!
    Quote Originally Posted by Scarsandtears View Post
    Thats what i figured, just wondered if with the IceTech stuff I had to do some more "fancy" cleaning.
    nvphatty
    Guest
    a 2nd cleaning with brake cleaner would be advised as well. Also use the alcohol on the caliper.
    El CicloPath!!!!!!!
    Nov 2012
    Was it a lot of oil on the pads? If it is just a few miniscul drops, you can sand them flat on 150 grit, douse with 99% OH, and then clean the rotors with OH and see if it's still ok after re-bedding them. You can also bake them.
    Sep 2012
    Re: Easy Question (I think), oil got on XT Icetech Rotor.
    I bought a set of XT brakes on EBay that had the faulty hoses which had leaked oil all over the pads and caliper. While waiting for replacement parts. I just put the oiled pads in a frying pan and "cooked" them till they stopped smoking. Cooled, then installed on bike. I used the pads for a couple hundred miles last season and still plan to use them till they wear out.
    On a side note. I did have the seller refund me a good chunk of change for the poor description of the brakes. And shimano replaced the lines and pads under warranty. Got a heck of a deal on some XT brakes.
    Sent from my PC36100 using Tapatalk 2
  1. Easy Brake Adapter Question
    By TaupoRider in forum Brake Time
    Last Post: 11-16-2012, 04:29 PM
  2. Easy 1X9 question
    By robc in wi in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-22-2012, 10:32 AM
  3. Easy Brake Upgrade Question
    Last Post: 08-03-2012, 12:41 PM
  4. Quick and Easy Brake Question
    By clark3554 in forum Brake Time
    Last Post: 06-27-2011, 07:58 PM
  5. Easy question about shifter.
    By Kamil in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-12-2011, 04:00 PM
