Results 1 to 2 of 2
    Reputation: TaupoRider's Avatar
    Easy Brake Adapter Question
    I had Avid brakes and 185 rotor on my 2011 Camber but I have swapped to a XT/180 Icetech set up on the rear as you can see the calliper doesn't quite line up any more do I need to purchase this part to get everything fitting again?
    Adapter: Bicycle - Shimano Rear 180mm Brake Adaptor - shimano - mounts / adaptors - brakes - mountain - parts
    Photo:
    Attached Thumbnails Attached Thumbnails Easy Brake Adapter Question-img_1048.jpg
    worked out it is the one.
