Results 1 to 3 of 3
Thread: Drum brakes
    Drum brakes
    Are there any drum brakes worth using?
    "The man is richest whose pleasures are the cheapest" Henry David Thoreau (obviously a single speeder)
    "...everytime you throw something away your load gets lighter..."
    Reputation: AlliKat's Avatar
    why would you want drum brakes? They mostly exist because they are fairly easy/cheap to manufacture. Discs work quite well. Rim brakes are generally a little lighter.
    Oh sh!+ just force upgraded to cat1. Now what?
    Best thing about an ultra marathon? I just get to ride my bike for X hours!
    The Aria, but they are really for tandems and meant to be used as a drag brake (speed control on long descents). I believe they require a 150mm rear axle spacing. Also, with the widespread use of disc breaks it appears these are slowly disappearing. Most newer high end tandems are coming with Avid Mechanicals with 203 rotors front and rear.
    Riding slowly since 1977.
