Results 1 to 41 of 41
    DOT fluid, how caustic is it?
    i sometimes fiddle with my magura brakes, which means a lot of mineral oil on my hands. what happens if i get DOT fluid on my skin? if its dangerous, why not replace it with mineral oil?
    Reputation: 29Colossus's Avatar
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    Quote Originally Posted by brake jack
    Because the seals, and system overall isn't designed for mineral oil.
    ups and downs
    Here's Material safety data sheets for DOT Brake Fluid
    http://www.championbrands.com/MSDS/1400.PDF DOT 3
    http://www.spectro-oils.com/images/m...GSBF%20MSD.pdf DOT 4 and 5.1
    Its no problem at all as long as you wash your hands/affected bike parts fairly soon.
    Dot fluid is easily diluted in water.
    However, leave it on the bike and you can kiss your paint job goodbye
    SLX
    SLX is offline
    Aug 2005
    Ive spilled it on Anodized surfaces never cleaned it up and seems ok.
    Seen it semi desolve electrical tape.
    One Question, how does this stuff hold up in contact with epoxy? Im fixing the cap in for the reservior part of a disk brake.
    Reputation: Danke's Avatar
    DOT brake fluid has a higher boiling point than mineral oil so your brakes will perform consistently longer under hard use with DOT than with mineral oil.
    pbj
    pbj is offline
    Dont Use DOT w/Magura
    There are several version of DOT brake fluid, 3,4 and 5. All are designed around good low temp viscosity, high boiling point and the ability to handle a certain amount of moisture <3%. All contain corrosion inhibitors to help prevent rust in the presence of moisture. Type 3 & 4 are basically ethylene glycol and very similar to antifreeze. Type 5 is way more advanced and is actually silicon fluid, which has the highest boiling point of most any fluid and the best chemical compatibility. None are particulatly toxic with occasional skin contact, obviously ethylene glycol is toxic to ingest. Mineral is still probably the least irritating to the skin. None of these brake fluids are corrosive otherwise they'd eat up your brakes insides. All are organic/inorganic solvents of some sort or another. As for compatibility with your Magura brakes, I would not recommend using any thing except mineral oil as that is what the seals have been designed to be compatible with. If you do use one of the other fluids there is a very good likelihood the seals and orings will swell causing sticking and eventual leaking requiring complete replacement.
    Good with your decision..
    Meh.
    Reputation: XSL_WiLL's Avatar
    You forgot about DOT 5.1. 5.1 is still glycol based.
    DOT 5 is not hygroscopic like the glycol based DOT 3, 4, or 5.1. DOT 5 also often results in a "spongey" feel.
    pbj
    pbj is offline
    Your are right, for bicycle brakes I did not think the distiction was that important. Also why should DOT or any brake fluid feel spongy? All fluids are incompressible,unless they contian air. Does one intrain air (foam) more that the others?
    The fluid absorbs moisture from the air. Even though they seem sealed every brake has breather holes. When the temp goes up the water boils, bubbles, and then the bubbles of air are what compresses. The more moisture absorbed the lower the boiling point vs.what's stamped on the bottle.
    Water accumulation leads to corrosion.
    DOT fluids absorb water which inevitably leads to corrosion, then stuck pistons or other moving parts. I prefer mineral oil for that reason alone. DOT fluids really need to be flushed annually, especially if you are running a brake system with minimal fluid (lightweight systems for example).
    One thing I have been trying to figure out lately is if mineral oil can be safely used in brakes designed for DOT fluid. The other way around seems like trouble for sure, but since mineral oil is less "reactive", I wonder if it would be OK in systems designed for DOT?
    bang
    Reputation: Cyco-Dude's Avatar
    probably not. systems that use mineral oil, from what i understand, have ways of keeping the heat from the rotor / pads boiling the mineral oil (such as maguras brake pads that have a heat shield i think?). if you put mineral oil into a system that uses normal brake fluid, you would probably boil the mineral oil in no time, which is not a good thing obviously.
    Why I don't think heat dissipation is a problem.
    I thought about heat, but found that Magura Royal Blood, for example, has a boiling point of ~383 degrees F. Since it doesn't absorb moisture, the boiling point won't degrade much as the fluid ages, unlike most DOT fluids. The minimum wet boiling point of most DOT fluids is quite a bit less than Royal Blood.
    Some manufacturers specify DOT 5+, but many allow 4 or even 3. I haven't seen any manufacturers specify a minimum boiling point, although most want you to use their brand of fluid (minimum boiling points definitely vary between various brands of the same DOT # fluid). Hope specifically states mineral oil will damage their braking systems, but doesn't offer any details.
    Also, the heat dissipation is proportional to the amount of fluid & weight (mass) of the system. Most brake systems are too close in these respects for it to matter much - at least for any common intended use.
    So unless some manufacturers are really pushing the limits (which I doubt), heat isn't obviously the issue. That's why I've always thought seal compatibility must be the issue, but I can't find any reason to believe seals that are DOT compatible wouldn't be fine with mineral oil.
    Has anybody experimented with mineral oil in DOT brake systems?
    Don't Do It!
    OK, middle school science class time as an example of what will happen if you switch fluids between systems.
    Take a gummy bear and throw it in a glass of water. What happens? Your bear swells up a couple sizes and becomes fragile, falling apart at the lightest touch. The same thing happens to seals formulated for DOT fluids when exposed to petroleum distillates (i.e. mineral oil) or when seals formulated for mineral oil are exposed to DOT fluids. Then you're looking at a heck of a costly rebuild as ALL rubber, pistons, and hose of the brake will need to be replaced due to chemical damage. May as well buy a new brake due to those costs. No good!
    Also, make a point to differentiate between DOT 5 and DOT 5.1. 5.1 is compatible with MOST DOT formulated systems (check with the manufacturer, follow their instructions so you don't void any warranties). DOT 5 can cause the same kind of seal damage as mineral oil, so again, follow manufacturer's instructions and save yourself some grief.
    The biggest thing I've seen between the two fluids is that DOT fluids have a more consistent feel across a broad temperature range, with the major change in lever feel coming from the temp of the seals. It gets cold up here and all hydros feel heavy in the winter, but my experience is the Shimano/Magura systems feel heavier due to the viscosity of the fluid changing in temps. I could be off base here, but it's my experience, yours could be different.
    The ability to absorb heat is one thing, but the main point with brake fluids is to control the thermal expansion of the fluid. They take up less volume for a given temperature increase than, say, water or motor oil, so they don't pump up as much, and the reservoir doesn't need to be as large. Heat dissipation is primarily a function of the mass at the caliper/rotor interface. The more pad contact (and ergo the more metal at the caliper) combined with larger rotors serve to dissipate the heat to the ambient atmosphere, away from the brake system as a whole. Hence, you don't rock Hope Minis on a V-10. Wrong tool for the job, like throwing the brake from a Festiva on a F-350 with a 30' trailer. Which is why all the major players are coming out with DH/FR specific brake sets. Bikes have evolved, and now the component manufacturers are evolving along with them.
    You must have went to a good middle school.
    Your analogy is amusing, but not very convincing. I'm not a chemist, but it surprises me that a seal formulation that can withstand DOT fluid cannot withstand mineral oil. So do you know for a fact that the seal materials of bicycle brakes could not possibly be compatible with both types of fluid? Can you provide a reference?
    PS. I have also noticed better brake performance from better DOT fluids.
    PPS. I did find one reference to support DOT seal incompatibility with mineral oil, but nothing specific to bicycle brake systems & seals. There are so many types of seal material. Perhaps the type of material used in DOT systems is very specific though?
    bang
    well, i'm sure you could get a seal kit from whatever brake you're using, and test it by putting it in a jar of mineral oil and let it sit for a few months. what's wrong with spending a few bucks in the name of science!
    When you do the test, also check and see if the seals and o-rings get a bit harder.
    We use the same seals (nitrile rubber) for ethylene glycol, and oil in my business and it does work well.
    So it must be the additive that can cause some of the issures.
    Big question I got is who cares, just use the right stuff.
    Good idea.
    That's a good idea, but I'm not sure I could easily test all the important parameter. Swell would be easy to measure, but there could be other effect - hardening or other deterioration, for example. The other effects could be even more dangerous that seal swell. It is worth a try though if I can get a complete seal kit!
    That's exactly my point.
    I don't know if nitrile is what is used in brake systems, but I do know there are many seal materials. I don't know what material fit the needs of bicycle brake systems. Bicycle brake systems are smalller than any other hydraulic brake system I can think of, so maybe it is possible a material compatible with both fluids is available for this specific application. It seems more likely that manufactuers would use the same materials found in traditional brake systems, but who really knows?
    I personally believe mineral oil is a better fluid for bicycle brake systems. It has a lower viscosity, absorbs less (if any) water, is less corrosive to what is around it (including me), & seems to have adequate heat characteristics in the right formulation. I agree most people just don't care, but I am curious & that's obviously why I am asking.
    As a matter of fact, B R H,...
    yup, I do have experience with this matter. Another shop in the area that shall remain nameless bled up a a guy's Sole brakes on his Fisher with the same bleed system that they used for bleeding Shimano's brakes. The residual mineral oil was enough to cause the seal swelling as I described. Needless to say the cat wasn't too happy to have his brake crap out in the middle of a ride. Removed the res cap from the brake and the bladder just ballooned out of the reservoir. Master cylinder piston had to be blown out with compressed air. Call to Hayes and I was given the facts of what is termed a 'contamination', as well as the analogy I used. Other shop did fess up and cover the guy's expenses (props!).
    I bet the reason you don't see much more than the labelling of individual brake systems specific fluid requirements is that the manufacturers think we wouldn't be fool hardy enough to use a different fluid than recommended by them. Apparently not always the case however. This is where I totally agree w/ jeffscott. Use what's recommended and ask the questions to the manufacturers. They know the 'why' to these questions better than a bunch of us on a forum for sure. Heck, they make the stuff. Gives 'em a leg over us!
    College Boy
    Reputation: Timeless's Avatar
    Quote Originally Posted by pbj
    little false there. All fluid is compressible to a degree yes including water. Some fluids are more compressible than others.
    Might like to point out that you can compress most fluids to the point where they will turn solid.
    General if the fluild feels spongy in the break line it is because water is in there and water turns into steam.
    SLX
    SLX is offline
    Aug 2005
    Quote Originally Posted by juancancook
    The wonders of our public education system......
    Reputation: Carbon Ken's Avatar
    Mar 2005
    It drowns of course!
    So it won't work with that model Shimano. That's good information. Thanks. Do you know approximately how much the repair parts cost?
    I agree the manufacturer should know, but often getting that information is not as easy as you might think. The design engineer will know for sure, but most likely anybody you can contact will not. Either way, most companies would rather just be safe & recommend their fluid for obvious reasons.
    I totally agree that this is not something people should take lightly & just go out & try.
    There is indeed a seal material suitable for brake systems that is also compatible with both fluid types. It is called TFE propylene. If my test seals fail, I may try to find appropriate replacements made of this material. It's expensive though & obviously won't work if bike systems use any proprietary styles or sizes. It might not be possible to replace the bladder/expansion membranes that most brake systems use though.
    Quote Originally Posted by SLX
    Actually, it was a valid demonstration. He used it to demonstrate the hydrophillic properties of gelatin, a property that DOT fluids share ironically, though they exhibit it in a different way. Take a half glass of water and a half glass of brake fluid then dump them into the same glass. That one we did in auto shop and is pretty freaking cool.
    Are you sure? How many gummy bears did you use in your test sample? What were their ages? Had they ever had swim lessons? I thought all bears could swim. Maybe gummy bears bloat & float?
    ballbuster
    Reputation: pimpbot's Avatar
    I don't think that is true
    Quote Originally Posted by Danke
    Bicycle brakes are almost always fully sealed. All of the brakes I have had apart have some sort of accordian bladder in them to let the fluid out and allow for the pads to wear.
    Car brakes are not sealed. That's why you sholuld change your brake fluid every now and again on a car. Not really needed on bikes, except to purge wear particles out of the system.
    Not true. Automotive brakes are definitely fully sealed. However, most automotive brakes cannot be "flipped over" without air migrating into the lines from the reservoir simply because the reservoirs are not usually completely full of fluid. The basic operation is virtually identical.
    Despite the differences, most DOT brake fluids still should be changed every year or 2 at a minimum. Even a tightly sealed container of brake fluid will absorb water & should be discarded after 2 years.
    The fluid from my Hope Minis was dark brown after 1 year. A few months later the pistons were seized & obviously corroded.
    Gravity Rides Everything
    Reputation: endurowanker's Avatar
    Quote Originally Posted by B R H
    the reason that DOT fluid is designed to absorb water is to PREVENT corrosion inside brake systems. if it's absorbed into the fluid, corrosion is less likely. any water that gets into a mineral based system is likely to pool somewhere and corrode stuff.
    there's a reason they use brake fluid in brakes.
    oh my god!
    i opened the thread when i was on leave from my reserve duty. imagine my surprise, to find the thread still floating and full of replies as i return.
    despite of a lot of may-bes and gummy bears, juans example of the damaged hayes sole answered my original question - why not replace DOT fluid with the non corrosive mineral oil. saved me from a useless experiment.
    thanks a lot, guys
    If DOT fluid absorbs water to prevent corrosion, it sure doesn't work very well! Either that or I can't imagine what would happen with a fluid that didn't in an automotive brake system. I've worked on many, & the corrosion can be just terrible, even in systems that were maintained properly.
    All of the Marta brake sets I've worked on or seen have fluid that is as clean as the day it went in - zero signs of any contamination or corrosion. Whatever Marta is putting in Royal Blood is good stuff - it works great in bicycle brakes for XC at least.
    SLX
    SLX is offline
    Aug 2005
    Ic I think I get it now.
    The experiment with dot fluid sounds pretty cool.
    Reputation: Grumpy's Avatar
    Jan 2005
    Not very, if you look at MSDS sheets on mineral oil and dot fluid they are similar in reactions and required precautionary measures. (though they vary in specifics) Basic rule of thumb (this is just common sense stuff really) wipe up any spills (with DOT you can also flush with water), and wash up after any contact (and don't ingest or breathe;-)
    Don't ever substitute one for the other the seal materials are not the same.
    Lastly, XSL_WiLL is correct about the DOT5 it defiantly feels less firm (spongy) and more sluggish than the same system filled with DOT4/5.1 (conversion of DOT4/5.1 systems to 5 is fairly easy, the reverse is straightforward but labor intensive (owing to DOT5's stickiness, it is difficult to completely flush. ) Also while dot 4 and 5.1 can be mixed (systems topped up with) DOT5 should never be mixed with any other brake fluid.
    SLX
    SLX is offline
    Aug 2005
    Ok I also have noticed "the gummy bear effect" when I was bleeding my rear Hayes hfx 9 yesterday. Not in my brakes but in the syringe that I used to bleed the brakes; it was an older one that I use to measure oil. The plastic was still OK, but the rubber plunger was swollen like a baboon in heat. Ok not that swollen but enough that it was not usable any more. Yea wrong seals = not good.
    I am a little concerned. I used a seal I got from ACE Hardware (correct size) to fix my nixon air fork when I ripped the old one. I wonder what the oils are doing to that thing!.! So far its working well even better than the old one with a bit of 'stickshon' that wont go away.
    Jan 2005
    I would think you are OK most hardware store O-rings should be resistant to petroleum based oils and greases. (though specific additives could affect them, though unlikely)
    (I assume you are talking fork oil or a petroleum based grease like slick honey (the nixon is semi bath isn't it?))
    I would not however ever use a generic seal in a brake (a failure is just too risky) always use factory (or OEM specified/certified) parts in hydraulic brakes.
    Lastly this whole "DOT fluid is caustic/mineral (petroleum) oil is wonderful" BS is just marketing hype. Don't buy it, DOT fluid does have a number of peculiarities, but it was engineered (designed that way) to be hydraulic brake fluid so it (obviously) has a huge number of positive attributes in that use (that is why it is used in 99% of the hydraulic braking systems on the planet)
    There is nothing (inherently) wrong with using oil either (it has it's own peculiarities), pick the brake system that has he characteristics you like/want and use the fluid that the designers (manufacturer) recommend in the system. (and you magura folks; quit spreading FUD)
    MSDS for Mineral Oil?
    Please excuse my highjack here -
    I'm about to ship my raceline D brakeset and was told by Magura USA that it uses mineral oil. So I would like to read up, and maybe even include a copy with the shipment , of the MSDS for mineral oil. Anyone know where I can see an accurate and valid copy?
    Jan 2005
    Quote Originally Posted by ecrock45
    The original supplier (OEM or distributor) of the product is responsible for creating the MSDS. (because different mineral (ie petroleum) oils will, due to specific modifiers or additives, have different specifics.) If Magura does not have a MSDS available you could google MSDS Mineral oil and likely get a boatload of similar MSDS sheets
    However...again, I will repeat; with most mineral (petroleum) oils (synthetic or organic) are fairly benign, common sense is the rule. Clean up spills, wash with soap and water (petroleum film will not rinse off with water and requires a polar solvent or added surfactant (ie detergent) to remove) and try not to eat it, breath it or get it in your eyes.
    danke.
    I'll call magura monday.
    lurk
    Sep 2013
    Untitled Document if helps with bleeding... the day is still young.
    Quote Originally Posted by pimpbot View Post
    Since the wayback machine is on I'll expand. You are confusing open and closed with sealed. An open system like on a car, motorcycle or in bicycle terms the brakes from Shimano is still sealed. The closed systems like Hayes and Avid are also sealed.
