    does rotor size effect brake jack?
    Does rotor size effect the amount of brake jack on a single pivot frame such as a Heckler or a Bullit?
    Reputation: Dougal's Avatar
    Quote Originally Posted by rug wheelie
    No it doesn't.
    Hecklers (like all single pivots) try to squat under rear braking.
    Owner of www.shockcraft.co.nz and NZ Manitou Agent.
    www.dougal.co.nz Suspension setup & tuning.
    SPV Devolve
    The only affect the rotor size will have is better leverage on the wheel for stopping power.The bigger the rotor,the less you will have to pull the brake lever and the better the modulation will be.
    Reputation: DJrider04's Avatar
    The bigger the rotor, the more heat that will be dissapated.
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. best V brake pads? not SS specific...
    By jh_on_the_cape in forum Singlespeed
    Last Post: 08-11-2004, 03:04 PM
  3. Is NRS brake jack worse with V brakes
    By RePete in forum Giant
    Last Post: 06-11-2004, 09:48 PM
  4. Analysis Gurus: Astrix Solo
    By Speedub.Nate in forum Shocks and Suspension
    Last Post: 06-07-2004, 07:28 PM
  5. Does Trek Liquid get brake jack?
    By Vermonter in forum Downhill - Freeride
    Last Post: 06-01-2004, 10:30 PM
