Results 1 to 29 of 29
    Mar 2013
    Do yourself a favor and get Shimano XT brakes
    I had an Elixir 1 setup on my GT Sensor 9r Elite and GARBAGE doesn't even begin to describe them.
    I broke so many things on that bike in the 2 weeks I had it that I had to return it. Then I jumped a few classes and got a Trek Superfly 100 AL Pro, which was appealing to me because it has brakes that aren't Avid.
    The modulation is just so much better, I don't have words that explain it. There were places where the Avid's would just lock up the wheel and make me crash... then I go somewhere steeper with the XT brakes and I can go down as slow or as fast as I want. The confidence they give is incredible.
    Do yourself a favor and spend the money, unless of course you already have equal or better
    Jun 2012
    Tx for tip. You haven't lived unless you have tried some dialed in formula brakes
    See what I did there. Same outrageous statement(still true
    I'm just messing with you
    Reputation: wv_bob's Avatar
    My turn for an outrageous true statement ... if you read the forum, all brands have problem after problem except for Hope. Shimano's the worst because they're not user-serviceable.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Quote Originally Posted by wv_bob View Post
    Not sure how serious you're being, but I've had my Shimano M666s for two years, put on at least a few thousand miles and have had absolutely no issues. Is that outrageous?
    No more outrageous than me saying I've got a set of Elixirs that did the same thing although they need rebuilt now.
    Your M666 brakes have the mark of the beast anyway, they're immortal and indestructible.
    I can't believe that never occurred to me. Though, the beast is not indestructible and will be thrown into the lake of fire. I hope my brakes fare better than that.
    Quote Originally Posted by jsilva View Post
    Yeah because Shimano plastic parts would melt quickly in the fire ... OK, enough of that
    May 2013
    Smile
    Stop! You're making me want new Shimano XT brakes. I currently run Avid Elixir 1's, which came stock on my bike. I just bought new Alligator rotors and Kool Stop pads, in an effort to make the Elixirs "better," too. :-)
    Reputation: veritechy's Avatar
    shimano brakes are awesome. I've got the XT and XTRs. Excellent modulation and performance.
    Quote Originally Posted by veritechy View Post
    I've got the XT and XTRs. Excellent modulation.
    Not tried Hope brakes then, as you will understand what modulation in brakes actually feels like.
    Reputation: Bailey44's Avatar
    Dec 2010
    If you consider modulation as on and off then you are correct...
    Those who continue on about how Shimanos have no modulation and are on/off:
    It really doesn't matter if Hopes (or whatever) have 'better' modulation, there are those of us who are able to modulate our Shimanos just fine. They are sensitive for sure, and I suppose if modulation were even easier that could be nice, but it is not necessary since I'm not straining to modulate as it is.
    Shimano modulation is not at all on/off. I'm not at all a heavy guy, so if it were on/off I'd be very sensitive to it. Are you using 2 fingers to stop? These are really 1 finger performance, you don't need to grab them with multiple fingers...
    May 2013
    Any of you guys or gals running these nice Shimano XT brakes with non-Shimano rotors? You've got me considering buying a new set of Shimano XTs, and using them with my new Alligator Wind-Cutter rotors. Any problems you see in doing that? I searched the forums and found some info from others talking about it, and it sounds like it wouldn't be a problem at all. I've already opened the Alligators, but I haven't installed them, yet. So, I'd rather take advantage of using them, as opposed to paying another +/- $90 to get the Ice Tech rotors. Besides, I got the colored Wind-Cutters, and they look cool! Several places have the Shimano XTs on sale for decent prices right now. Looks like I could get a complete set, with adapters, for around $280ish.
    Reputation: GTscoob's Avatar
    I'm using IceTech XT braked with Magura Storm SL rotors just fine. And I'm fat so they modulate really great.
    dshoe70, I've used the Alligators and they work fine.
    Reputation: RS VR6's Avatar
    Using HS-1 rotors and they stop great.
    I brake with one finger only.
    May 2013
    @ veritechy and RS VR6...
    Thanks for the info! Any squealing from your Shimano XTs, and Alligator or HS 1 rotors? I currently have HS 1s on my bike now, and the Alligators sitting on the floor (waiting to be installed). Hoping maybe new Shimano XTs will help cure my squealing issue (back brake only, running Elixir 1s with HS 1 rotor). May pull the trigger on the Shimanos over this weekend.
    @ dshoe70
    No squealing unless I just washed the bike or the rotors get wet. Once they are dry it is fine.
    Reputation: proto2000's Avatar
    Running XT's with Hope floating rotors, awesome set up.
    Too many bikes, and just enough time to ride them.
    May 2013
    Hey dudes... Check it out...
    Think I'm going to order a new Shimano XT brake set. I'm wondering about the adapters I'll need though. I think the rear one is pretty straightforward. I guess I'd need the 180/74 post/back/51 IS for the rear. See my pic, and let me know what you think. For the front, I guess it would be the 180/74 post/front/74 post. Is that the way you see it, based on my pic of the current front-end set-up? I want to be sure to order the right parts, and this will be my first DIY brake job. Thanks for any help or confirmation you can provide!
    Attachment 808596
    Attachment 808597
    Attachment 808598
    Universal Cycles -- Shimano Disc Brake Adapters
    Shimano Mount Adaptor Front Post to Post 180mm | Buy Online | ChainReactionCycles.com
    wyrd bi ful rd
    Reputation: chinaman's Avatar
    Quote Originally Posted by proto2000 View Post
    +1 ...
    Brakes sometimes squel because the pads are contaminated.
    May 2013
    Okay... I did myself a favor, and pulled the trigger on a new Shimano XT brake set earlier this morning. They should arrive either late this week, or early next week. I'm excited! I hope they're all they're cracked up to be. I went ahead and spent about $30 more to get the new 2014 model, too, with the newly redesigned clamping mechanism. I also got new Shimano front and rear adapters, too. I'm going to set em' up with my new Alligator Wind-Cutter rotors. If any of you know of any good tips or tricks for the install process, which aren't in the standard install instructions, then please let me know. This will be my first DIY brake installation project. From everything I've read so far, it sounds like the process is pretty easy and straightforward though. :-)
    Reputation: ghettocop's Avatar
    Hearing Shimano described as having better modulation than Avid is certainly not the "normal" way these two brakes are talked about. I concur that Elixir one's are pretty poor performing and used mostly on entry-level type bikes, but I would not describe any Avid brake "going all the way back to their Linear pull models", as an on/off switch.
    251 is offline
    Reputation: 251's Avatar
    While XTs are certainly great brakes, I've had a few sets of Avids and they've also been great. That said, I've never tried an Elixir 1. My current Elixir CR Carbons and XO Silvers are excellent. I personally prefer the feel of Avid brakes over Shimano, but that dosen't really make one better than the other. YMMV, apparently.
    Dave
    +1 for XT brakes. I heard nothing but great things about them and decided to use them on my new build. Night and day difference between them and my previous brakes (2011 Elixir 5). I was bombing down some tight single track when another rider came from the other direction looking for his riding partner (around a mild bend of course). I was able to brake both quickly and in a controlled manner, despite it being an emergency stop scenario. They have helped manage my speed nicely on the short downhills I ride as well. Very little pressure needed to activate them. With that double-edged sword in mind, I haven't over-braked at a low speed yet either.
    May 2013
    +1 for XT/SLX Brakes Ive got nothing but praise for them.
    Reputation: AmericanTemplar's Avatar
    Another +1. I had Elixirs before and I can actually clean sections now that intimidated me before. Sections where precision is required and if my rear wheel locks up I could be thrown off of a cliff.
    Reputation: mazspeed's Avatar
    Quote Originally Posted by Bailey44 View Post
    I was just going to say the same thing. Although the XT's are very good and reliable brakes. Worth the money.
  1. Replies: 7
    Last Post: 07-12-2013, 07:54 PM
  2. Shimano XT Brakes
    By 4nbstd in forum Where are the Best Deals?
    Last Post: 02-20-2013, 05:32 PM
  3. Shimano V-brakes
    By LBIkid in forum Where are the Best Deals?
    Last Post: 02-14-2013, 07:35 PM
  4. shimano brakes - do I need shimano rotors?
    By Gabe3 in forum Brake Time
    Last Post: 03-15-2012, 07:15 PM
  5. shimano brakes disk brakes
    By hainesm in forum General Discussion
    Last Post: 05-20-2011, 04:04 PM
