Results 1 to 3 of 3
    Not a Barry supporter.
    Reputation: Crash_FLMB's Avatar
    Do I need a new bladder for my Hayes Hydros?
    I've never taken apart any hydros b/4 but I'm ready to concur them. I think it's the only part I haven't taken apart or rebuilt yet on the bike.
    Anyway, the bike took a nasty fall today on a slippery bridge. Luckily it was at the very end of the ride. Here's the problem. The lever is still attached to the pin that goes into the bladder, but it appears the pin was pulled out of the bladder. Or whatever holds it in there. The rubber bladder part is still connected. It looks like the pin just 'popped' out of sockt per say. If I take it apart, will I discover it just 'popped' out or is the bladder hosed? I'm guessing the latter but since I've never worked on them b/4, I can't way for sure.
    I forgot to mention that these are the older style brakes. They're about 4 years old. So they aren't the HFX ones.
    Thanks to all the experts who reply!
    Why would I need more than one gear?
    @A_SingleSpeeder
    EPA = crooks!
    Reputation: skywaybuzz's Avatar
    Should be easy to fix.Look on Hayes website for master cylinder replacement instructions, you will need small snap ring pliers to get to the washer that the ball end of the "pin" pulled thru. If you can re-flatten the washer and reasemble, possibly rebleed you will be good. hardest part might be getting the small snap washer off, but with patience its easy. Don't let it fly away or you'll lose it . The bladder is the rubber that surrounds the master cylinder
    Thanks skywaybuzz! That was exactly the problem. And hydros aren't that hard to work on.
    @A_SingleSpeeder
    EPA = crooks!
  1. How to use Avid 185mm rotor with Hayes Hydros
    By VT no 1 2 or 3 in forum Brake Time
    Last Post: 05-12-2005, 11:24 PM
  2. need help fixing leaking hydration bladder
    By guppie in forum Beginner's Corner
    Last Post: 07-25-2004, 11:23 AM
  3. Mech Disk Brakes...Avid or Hayes???
    By BlurryTrees in forum Downhill - Freeride
    Last Post: 03-20-2004, 10:51 AM
  4. Time For New Pads on My Hayes Hydros
    By Nim in forum Brake Time
    Last Post: 03-12-2004, 12:00 PM
  5. best price on hydros: Hopes or Hayes?
    By rpet in forum Where are the Best Deals?
    Last Post: 03-02-2004, 09:39 AM
