Results 1 to 11 of 11
    Do all rotors eventually warp slightly ?
    I have a set of 180mm rotors on my bike that have been in use for 2 light seasons. Never smoked or super blue'd. I was spinning the wheels on the stand and noticed they didn't run true - enough to make noise on the stand but not noticable on the trail. Do any rotors stay true or is this normal. thanks.
    Reputation: 006_007's Avatar
    I have yet to have a set stay true (either from heat cycles or dinging them on something).
    Used Hayes, Avid, Magura, Hope, 160, 180, 200.....
    Old man on a bike
    Truing your rotors occasionally is normal...
    suum quique
    Reputation: vk45de's Avatar
    how do you true rotors? with a crescent wrench?
    Old man on a bike
    I use a small adjustable wrench, but you can buy specialized tools from Park or Morningstar
    http://parktool.com/products/detail....=14&item=DT-2; can't get the morningstartools.com site to load right now.
    suum quique
    I wouldn't even bother truing them unless you cannot get the brakes adjusted properly. Truing rotors is a big PITA.
    Old man on a bike
    Quote Originally Posted by flow350
    How hard do you think it is? Sometimes you need a true rotor to setup brakes the way you like or to simply prevent rub/noise. In any case it's no more effort than most adjustments on a bike...
    suum quique
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    I have had to true rotors out of the box once (Hope), but I must be lucky, never had any rotor warp... Shimano and Formula and the Hopes I trued stayed true.
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    qua???
    truing a rotor takes 30-60 seconds tops ... find where it rubs - rotate wheel to access affected area - bend in desired direction - verify - repeat if necessary
    This is something that even the most ham-fisted mechanic can do quite easily.
    Or - did you mean this by PITA
    Honestly... ahh I give up
    I guess I just try too hard to get them perfectly true--like wheels.
    Dec 2008
    I trued my Tektro rotors 2 or 3 times in 14 months of use. No big deal.
