Results 1 to 6 of 6
    Feb 2005
    discs with steel frames?
    Anyone have good luck running disc on a flexy steel frame? I tried Hayes Mechs and they sang every pedal stroke...any ideas? I really would like discs...in fact I am building a set of disc wheels now and if worse comes to worst I WILL have the frame modified i.e a "prop rod" welded between the disc mount on the seat stay and the chain stay to stiffen the rear triangle just to run them. Mike
    hands up who wants to die
    Reputation: rpet's Avatar
    I think that stiffener is pretty common for disc-only lightweight steel frames. I would definitely have that added if you want the frame to last. My Steelman has one stock. It works great, though I weight 165 lbs with gear. YMMV
    You should probably run 6" disc to minimize the effect of the flex, as I'm sure you've figured out.
    A stiff wheel may help too. I mostly hear the singing sound during high-speed, brakeless cornering, not when hammering (sound is often coming from the front wheel, however.)
    -r
    Feb 2005
    thanks.
    Sounds like my frame will need adapeted. Figured.
    Quote Originally Posted by phobiaxc
    I have the same frame, under a different name, you are using.
    Everything is just fine with discs and I weigh 228lb
    Feb 2005
    awesome!!!
    PLEASE tell me which disc set up you are running!!! Mike
    Four pot XT 160mm rotor at rear
    The disc mount is close enough to the drop out,resulting in little flex.
    If the tube flex was a problem it would rear its ugly head with V brakes,
    after all they put force more toward the middle of the tube.
    I think a brace would be overkill, and quite ugly.
  1. I got my shipment of those unpainted OX Gold steel hardtail frames...
    By DeeEight in forum Bike and Frame discussion
    Last Post: 10-27-2008, 12:23 AM
  2. Issues with steel frames?
    By SpinWheelz in forum General Discussion
    Last Post: 09-27-2004, 12:35 PM
  3. Stainless steel frames
    By r1Gel in forum General Discussion
    Last Post: 07-21-2004, 10:32 PM
  4. scandium or steel frames
    By Raymo853 in forum Bike and Frame discussion
    Last Post: 06-07-2004, 10:00 PM
  5. Used steel road bike frames
    By iamhuxley in forum Singlespeed
    Last Post: 03-14-2004, 07:10 PM
