Results 1 to 14 of 14
    discs rubbing brakes
    For some time on my front wheel the disc rubs the brake pad at one point in its rotation. If it rubbed throughout the rotation, this would be a non-issue, but it seems to be affecting braking (braking is not as constant). Assuming the rotor was warped I replaced it and the brake pads, to no effect. Shouldn't the hub be aligned regardless of whether the wheel is perfectly true? I doubt I have truing issues anyway as I have not been riding that hard and use some pretty good wheels. What should I try next?
    I'm using Avid BB7s with Mavic Crossmax XLs
    Reputation: vk45de's Avatar
    Quote Originally Posted by 310ScottK
    If it's really as you say, clean the mount surface on the hub. Eyeball the rotor and see where where and how much it's off.
    Correct. That is the undisputed advantage discs have over rim brakes.
    cougarbait
    Reputation: Lambdamaster's Avatar
    Nov 2008
    it sounds a lot like the rotor is warped... also just in case, check rotor bolts for proper tightness. like vk45de mentioned, spin the wheel and look into the caliper to see which part of the rotor is rubbing, take a adjustable wrench, and true it.
    09AS-Rsl/09Six
    Owner, Spoke Apparel
    Reputation: meneone's Avatar
    My guess is that your caliper is out of alignment. Get down at eye level, watch the rotor as it spins through. Is there equal space on the left and right side of the rotor? If not, your caliper needs to be realigned. This is easy to do. PM me if you need a step-by-step. And yes, even a true rotor can rub only at one point if the caliper is not properly aligned.
    www.SpokeApparel.com
    T-Shirts for Mountain Bikers
    cougarbait
    Nov 2008
    Quote Originally Posted by meneone
    care to explain this to me??
    09AS-Rsl/09Six
    You've never had this happen to you? Dunno what to say.....I've seen this happen quite often.
    cougarbait
    Nov 2008
    I don't think it's physically possible for the rotor to rub at only one point if it is true.
    09AS-Rsl/09Six
    I understand. In theory it makes no sense. I've been working on cars and bikes for a long time. The solutions to many mechanical challenges are often overlooked becuase we use reason and logic as opposed to just trying what may seem simple and unnecessary. All he needs to do is check to see if the caliper is centered. Takes two seconds and is part of standard brake care and maintenance....
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    Quote Originally Posted by Lambdamaster
    it's not
    Honestly... ahh I give up
    cougarbait
    Nov 2008
    if his caliper was misaligned, and his rotor was true, then it would be rubbing continuously. The rotor is the only moving part when the wheel is spun, so how could it rub at one point if it is true??
    09AS-Rsl/09Six
    What if the caliper was misaligned for a while and the pad unevenly wore...then the caliper shifted again? You can't rule this stuff out guys. That's all I'll say about it.
    PS - great signature quote, highdelll
    Reputation: luckynumber9's Avatar
    I'm sure you guys have confused him with all this mechanical theory, hell reading this thread required more thought than I've put into anything all day -- and im still confused. I could add my advice but that would just interupt the flow of confusion. Im off to get another beer and reread.
    cougarbait
    Nov 2008
    then it would rub continuously, provided the rotor was true
    09AS-Rsl/09Six
    Reputation: siwilliams's Avatar
    Maybe the hub is not running true? If a replacement rotor is having the same problem, this is where I'd look.
