Results 1 to 3 of 3
Thread: Discs?
    Discs?
    im wanting to upgrade to disc breaks in the near future, as in this spring or summer, and i have to buy new wheelsets ontop of the disc breaks. My bike is around 10 years old, Its a Specialized Rockhopper Comp, do i have to worry about the frame and forks being disc compatible? Also whats the best value disc kit?
    Reputation: vk45de's Avatar
    Yes you have to worry about that, your fork may have it but I doubt your frame does if it's really a 1999. It should be pretty obvious if your fork has disc mounts - 2 holes 51, 68, or 74mm apart. In the rear look for 2 unthreaded holes 51mm apart or 2 threaded holes 22mm apart.
    one less car
    Reputation: B@dKarma's Avatar
    if no tabs, and if the dropout is flat, you'll need one of these: A2Z Disk Brake Adapter for frames without disk mount, anyone try one? got one and it works on my 00/01 TREK 4500
    nothing in life is real, so if anything goes wrong, blame the dead guy
