I was listening to Car Talk on NPR a couple of wknds about and Click and Clack mentioned brake pad grease to reduce squealing. They went thru a long dissertation as to why/how squealing comes from the pad/piston interface in the caliper (at least in cars). Just curious if anyone has tried this to fix the horrendous Avid noises?
I do not htink it would help. I'm an avid (pun intended) believer that the Avid rotors are junk and are just never true which causes the turkey calls. I'm riding Elixir 7s that came stock on my bike and hate them with a passion. My front rotor is the noiser of the 2 and it comes out of true no matter how much special attention I give it to keep it straight. The same goes for the rear rotor though it doesn't make as much noise.
In the past, I changed the brake setup on my hardtail from Avid BB7s to Hayes and the Hayes rotors are thicker and stay true and do not make constant noise like the Avid rotors. Avid brakes are horrible.
I dont think this is the case. I changed my elixir 5s to XTs but kept the avid rotors and no noise.
To answer the OP question, you should just read the turkey warble mega thread. One thing that does work is CRC brake adhesive.
I did the following:
If you havent previously bedded your brakes you can sand your rotors and clean with brake cleaning fluid. Sand your pads as well. You can google how to do this.
Make sure you bed your brakes - 15-20 slow stops from 10-15mph and then another 15 stops from a higher speed (you google proper bed procedure). Properly bedding your brakes can get you part of the way there to reduce the warble. If you havent bedded your brakes you really need to. It definitely is a pain though, especially since you have been riding with them already so pretty much need to do step 1 (cleaning the pads and rotors). I did do the above but it is possible it wasnt necessary.
make sure the calipers are centered on the rotor (google for how to align calipers). I do it by loosening the bolts, squeezing the levers, then tightening by alternating between bolts. Then loosening one and aligning by eye, then tightening it gently, then loosening the other and aligning by eye. Shining light through helps. Spin the wheel to see if the rotor is true or making contact with the pads.
Remove brake pads and apply CRC brake adhesive to the back of the pads and where the pad contacts the spring. Do not touch the pad brake surface with your fingers. Ideally you would wear nitrile gloves.
I had terrible problems with brake noise but after I did this they were quiet. I started having problems with mushy levers so I bled them. The bleed wasnt that great so I ordered XTs. While waiting I bled again and was more careful and I was getting full power. Since I already bought the XTs I just decided to keep them and sell the elixir 5s but I was able to get them to be quiet and have full power.
I am also not a fan of Avid. I had Elixir 5s on mine and my wife's bike and swapped them out for some Shimanos. But we kept the rotors and all is well now. Not sure the problem is always the rotor.
To the OP. Try the grease. It may help. I used CRC Disk Brake Quiet and it did not help. It definitely works on cars.
I don't have the turkey warble on any of my Avid brakes, and I (still) have a set of Juicy 7, 3 sets of Elixir CR/2010 Code, and 2011 Codes. The only sound I get out of my Avid is the very high pitch squeal, which I think what you guys call CRC may help. I don't know if any one else mounts their rotors like I do, but...with the torx bolts in but not tightened, I twist the rotor into the rotor bolts before I snug them up on every wheel. I don't know if this is why I don't get the warbles tho.
The suggestion on the CRC was something I had gleaned from Car Talk. Anyway, it was a curiosity/attempt at a solution for those with the warble problem. But according to likeaboss, no dice...
Edit: I will go and check out that warble mega-thread tho...seems that it's a defacto thing w/ Avids, and I'm the outlier.
Toyota supplies a copper-based high temperature grease to be applied to the back of the brake pads. It acts as a noise dampener. My Avids CR's occasionally turkey wabble, but , organic pads have made it tolerable.
Turkey wabble and brake squeal I consider two different things.
By the way , Ray, from the Good News Garage, is a friend of mine. I'm not sure if he is Click or Clack.
I'm assuming you're talking about those Disco Brake pads? How are those for longevity and grabbyness? I just threw down on an order for 4 sets of Codes and 4 sets of Elixir semi-metallics...I run this combo pretty much exclusively for frt and rr, respectively w/ Elixir CR levers. TIA BW.
Everything is important in disc brakes. Like has been said, you first have to get them on straight. Sometimes it takes a while to get them right. Also, you can often get away with not bedding in your pads if you also have straight rotors and organic pads, but it doesn't hurt to go through the process. Once I know I have a straight rotor and the brakes are installed properly, I don't bother bedding in the second or third set of pads. Just go ride. The pad material is already on the rotor. I have owned every model of Avid rotors and it seems like every other one is not straight. The straight ones are usually quiet and the crooked ones usually suck, no matter what brakes you run them on.
The Alligator Windcutter rotors are cheap rotors that I have had very good luck with being true out of the package, but the minimal surface area means they fade much quicker. These may be a good solution if you don't ride long and steep trails. Run a thicker and heavier rotor that has more of a reputation for being true, like the Hayes or Shimano, if weight doesn't matter.
Since the Avid pads are bolted in (not floating with springs) automotive disc brake "quiet" won't help. i believe the howl is a resonation in certain rotors.
The biggest thing that cured my warble was pad placement. If the brake pad engagement was below the rotor pad area to where it was into where the "spokes" were it had a ton of noise. Shim the bolt with a 5mm washer or two to get it up to engage the braking surface only and the problem was 90% solved. Just a minute amount of the brake pad being below the bra
king surface will make noise.
I paid attention on today's ride. Front squeals, rear does not; both Elixir 1s. Well, the front pads are in contact with the rotor spokes (just a little) and the rear ones are not. Bike is in the garage drying off, and I'll be looking for some suitable washers in a couple of minutes.
Edit - There was a bit of play in the caliper mounting holes, so I just slid the caliper as far away from the center of the rotor as possible before tightening the bolts. We'll see if that was enough or if I have to add washers.
As per Firebike and others above, I moved the caliper as far from the axle as I could using the play in the caliper mounting holes. I did not any any washers yet.
On a pretty short ride tonight, but no squealing. So, this might have been enough. I'll keep an eye on it, but things look promising!
I eliminated turkey warbble (at least for now) in the front by switching to red pads. The rear still squeals when wet and the pads contact rotor spokes. I'll move the caliper back to clear the rotors and report if squealing is reduced / eliminated.
EBC Red labels. Might be the organic ones people talk about. I was adviced that they grip better but wear out faster. Squeeling when wet, not at all when dry. Got rid of the warbble, though.
The rear is still squeeling even after moving the caliper so that the pads surely don't touch the rotor spokes. Might have to try something else.
I have grown a dislike towards the angle-adjusting convex + concave bits on the caliper mount. They seem to have a "locked" position they revert to, even after setting the caliper angle according to the disc. I'm thinking of replacing them with solid bushings and take care of caliper alignment by facing the adapter mount. I'd only use the elongated holes on the caliper to adjust it sideways and that's it. I'm wondering if this kind of mounting method would be more rigid and reduce resonance. Any thoughts or experience on this?
According to EBC:Red pads. "These are extra high in friction but still an organic pad for use on all types of rotors' so not a full organic such as their Green pads:These are a high quality organic formulation producing an excellent all round replacement pad for pleasure riding, cross country and trekking.
I tend to agree with your findings Saul however my juicy 5's on my full squish have them along with organic pads and the only squeal is when wet otherwise none.
Fwi. I've never had any long term audible issues. Used juicy 7, xo, and xx. In order to reduce the chances of cps washer bedding. once rotated one of the washers 90*. Also to reduce the chances of any torque induced movement. I have always alternated between the caliper bolts. Turning each just a hair at a time.
I just got in from a ride, and both of my Elixir 1s now pull to the bar. If you pump the lever a couple of times, you build up pressure and they work briefly. They're less than 2 months old FFS.
Now I need to figure out whether it is worth sending them in under warranty (time and shipping cost) or not. They'll probably do a bleed and send them back. LBS said $40 to bleed the pair when I checked with them a while ago, so more $ but less time off of the bike. Or I could buy a bleed kit ($40 for Avid one, less for others w/o bleed blocks) and do it myself.
Or I could buy new brakes from a different manufacturer...
Saul - yeah, I understand that, its just disappointing to have to do it so soon.
My other brakes are Magura and I can bleed them myself pretty easily. I've had to do that maybe every two years since they were new in Fall 2007. They're mineral oil though so would need a new bleed kit for the Avid DOT fluid.
Since the pad trac was making slight contact with the disc spokes i used 5mm shims/washers between caliper & fork mount to move it farther away and test rode but to no avail it continues to warbble away. BTW this is not with Avid but Hayes stroker Tr brakes and Magura storm sl disc's. My next test step is Organic pads.
To no avail the above had no effect..........however the following did.
I've done proper burnishing of pads to no avail, tried yet a 2nd set with proper bedding in but sadly no better.....UNTIL the zip-tie mod on magura storm SL discs, i installed 3 smallish ties spanning 2 spokes each on the front and the instant reduction in warbble / squeal was significant to the point i can accept what little remains. I also installed 1 zip on the rear spanning 3 spokes and it too was instantaneous as though a damper of sorts was added (actually was).
Overall my feeling about this is perhaps the magura disc spokes are too thin width wise in their effort to shave weight, hhmm maybe, maybe not but perhaps an mech engineer can expound on such if there's one here.
UPDATE: the zip-tie method work briefly but the squall returned as before so i have now installed a pr of EBC organics and followed the break in method but again the turkey came howling back at me...FAWK!!
Ive been having the same turkey warble with my 11' Avid Elixer 5s. The worst part is the whole bike vibrates terribly. Ive already tried a new rotor because my old G3 center lock had some play in it. It did nothing and costed me 50 ish at my LBS. They wont help me out with the problem either. Do you think this rotor would get rid of my problems? I need a 180mm so pickings are few and far. Shimano RT64 Rotor OE > Sale | Jenson USA Online Bike Shop
Edit: I have tried everything you guys have mentioned before. This is a last ditch effort before replacing my whole system.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
