I have new Avid Juicy 7's and I pretty sure I bedded them in exactly wrong. I was so excited to get out on my new ride, I took it out right after a rain and pounded around in the mud for a few hours. Lot's of steep up's and downs and thick mud. It got so bad that I had to pour water through the calipers to get the mud out. You could hear it grinding. Stupid me. The next ride featured a quite a bit of brake squeal. What did I expect? Anyway, I cleaned the rotors with alcohol and rubbed the pads with alcohol as well. They still squeal. I inspected the rotors last night and they are glazed with rings in them. The pads are glazed as well. After reading as much as a could about it, Here is what I have planned.
Make sure all the bolts are tightened.
Clean the Pads by removing the pads and rubbing them in a circular motion on top of emery cloth which is on a bench until the glaze is removed.
Clean the Rotors:
I have found conflicting info on cleaning rotors. Should I just use a brake cleaner like clean streak or should I use a fine emery cloth on the rotor while I spin the wheel?
Then I should bed them in right. A long slow descent with the brakes applied lightly.
Any other suggestions?
Thanks for your time.
Clean the Rotors:
