Results 1 to 11 of 11
    better than I deserve
    Reputation: roblee's Avatar
    Disc and H. dropouts?
    Can someone confirm for me that the use of a larger dia. rotor will eliminate the necessity to take the Caliper off to remove the rear wheel on bikes with horizontal dropouts?
    And if so what size is needed?
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    What frame are we taking about, I don't think this is a widespread problem...
    Check out my SportTracks plugins for some training aid software.
    g3h6o3
    Oct 2007
    That doesn't answer my question. What frame is it?
    Usually, brakes mounts are "slotted" on frames with horizontal dropouts such that you can optimize the caliper position to the position of the wheel.
    I better understand your problem but can't see how much "overlap" there is between caliper and rotor when removing the wheel...
    since 4/10/2009
    Reputation: Harold's Avatar
    not on my On-One Pompetamine.
    <a href="http://www.flickr.com/photos/8007861@N04/6278709960/" title="On-One Pompetamine by mtbikernate, on Flickr"><img src="http://farm7.staticflickr.com/6217/6278709960_1586df72a3.jpg" width="500" height="333" alt="On-One Pompetamine"></a>
    Azonic DS-1 I tried to take the wheel off and it does make contact with the top of the caliper.
    I read somewhere that using a large rotor allowed the removal of the rear wheel without taking the caliper off but can`t remember where?
    Well I don`t see how that would change anything? It`s two bolts to take off not that big of a deal.
    Quote Originally Posted by NateHawk View Post
    Like
    g3h6o3
    Oct 2007
    This is popular as well
    PissedOffCil, that one solves two problems.
    If I make an adapter that is slotted on the bottom bolt, I could loosen that bolt and pivot the caliper upwards and take the wheel out.Might be a fun project.
    g3h6o3
    Oct 2007
    we got astray a bit and didn't answer your OP however...
    I found that a 180 was enough on my Karate Monkey with a 185 adapter but it has slotted tabs that swing the caliber, not just slide it. You might have to go as high as 203. I basically think you might be screwed since you can't adjust your caliper position.
  1. MTB Disc Dropouts
    By blackgt in forum Frame Building
    Last Post: 07-16-2010, 01:42 PM
  2. dropouts with disc mounts?
    By metalray in forum Frame Building
    Last Post: 09-08-2009, 09:00 AM
  3. Disc tab + horizontal dropouts???
    By theycallmeE in forum Frame Building
    Last Post: 02-07-2008, 06:33 AM
  4. Dean has SS DISC Mod Dropouts now
    By OrBikbldr in forum 29er Bikes
    Last Post: 12-01-2005, 12:29 AM
  5. Source for SS Disc Dropouts
    By Objectionable Material in forum Singlespeed
    Last Post: 03-25-2005, 12:19 PM
