Results 1 to 2 of 2
    Phil from San Diego
    Reputation: Prexus2005's Avatar
    Mar 2005
    Disc brakes.. shwin shwin shwin shwin shwin..
    Both my front and rear disc brake/rotors are making the annoying noise while riding... is it because the rotor isn't perfectly flat/ture anymore or ? I thought disc rotors are usually pretty strong.. or could it be the hubs...?
    I have an entry level hardtail that came with Hayes Gx2 disc brakes and I'm assuming the rotor might be lower quality.. either that or it's the stock wheel/hub...
    What do you guys think?
    Phil.
    "El Whatever"
    Reputation: Warp's Avatar
    Quote Originally Posted by Prexus2005
    Phil.
    Check right upper corner on this page for FAQ's... if that's not enough come back at this place.
    The rotor is not prefectly true and needs truing. No biggie. Discs are sensitive beasts.
    Your problem has nothing to do with rotor quality.
    Check my Site
  1. Why are so many people using Disc brakes???
    By Cannonhead in forum Brake Time
    Last Post: 02-10-2013, 04:25 PM
  2. What are the BEST brakes on EARTH?!
    By norwoosg in forum Brake Time
    Last Post: 02-24-2005, 10:38 PM
  3. Disc...or V's...
    By BThor in forum Singlespeed
    Last Post: 01-20-2005, 04:47 PM
  4. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
  5. regular brakes and disc brakes
    By joshua_msu in forum Brake Time
    Last Post: 03-05-2004, 09:07 PM
