Results 1 to 3 of 3
    Disc Brakes on Old Frame
    I have recently aquired an old Giant ATX frame. I believe it's an ATX, not sure though. I'm looking to build it up with a set of disc brakes. It does not have the mounts on the back of the frame. Is there any disc setup that I can mount to the frame without those mounting points? I suppose I could have them welded on to the frame.
    -GIl
    Nevermind, I found the answer sorry. nm
    sorry no
    undefined
    Quote Originally Posted by gildomilo
    -GIl
    I have the same problem with my Trek Y22. I purchased a Woodman Disco System that provides the caliper mounting. This adapter requires either a special offset Woodman rear hub or modification of your existing hub. I purchased the Disco system but haven't yet performed the upgrade. Will post results, or lack thereof.
    The link to Woodman Components is http://www.woodmancomponents.com/
    TONY22
  1. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
  2. regular brakes and disc brakes
    By joshua_msu in forum Brake Time
    Last Post: 03-05-2004, 09:07 PM
  3. Tune Disc Hubs & Formula Disc Brakes??
    By Wirth in forum Weight Weenies
    Last Post: 03-05-2004, 05:20 PM
  4. A good cheap wheelset for disc brakes
    By micky in forum Wheels and Tires
    Last Post: 02-26-2004, 09:19 AM
  5. For those who have warrantied their XTR disc brakes....
    By mike@one-speed.com in forum Brake Time
    Last Post: 01-17-2004, 09:35 AM
