Results 1 to 17 of 17
    disc brakes are not stopping good
    My disc brakes are not stopping good at all. My linear pull brakes on the rear tire are doing so much better. What is causing this.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Info
    Formotion Products
    http://www.formot
    xnine
    not really an mtbr member
    Reputation: theextremist04's Avatar
    no, we need more info. what kind of brakes? what bike? etc.
    Former Bike Wrench
    have you burned them in or did you just put them on and do a quick driveway check
    i have ridden the bike alot
    some of the trails are muddy. could that cause it
    Jan 2005
    Nut holding the handlebar.
    Formotion Products
    http://www.formot
    i know what you are talking about but why would that help
    Jan 2005
    People are requesting you write some information in a attempt to help you and you wont respond. What brand and model brakes, are they mechanical or hydraulic, what type of riding, what bike are they on.
    So far you say the front disc brake doesnt work, it's a xnine?, you ride the bike and in the mud.
    Formotion Products
    http://www.formot
    i dont know the model but it is on a jeep bike and i ride on alot of rough ground and mud. They ust to stop great until it got muddy. Yes, dont say anything abouot my bike. i know it is crap
    Jan 2005
    Quote Originally Posted by hardtailrider 14
    Check here and see if you can ID it, http://www.jeepbikes.com/bikes/wranglerse.html
    If they were working good before getting all muddy it could be they need to be cleaned as well as replacing the cable and housing. A cheater way of checking the housing is to disconnect the housing from the stops and see how freely it moves on the cable, odds are yours are seized or close to.
    http://www.parktool.com/repair/
    http://www.utahmountainbiking.com/fix/index.htm
    If your riding and havin fun your bike is awesome.
    Formotion Products
    http://www.formot
    Old man on a bike
    Count yourself lucky if your brakes are on the tire and working for you at all!
    suum quique
    My bike is a jeep wrangler. alumonum frame hardtail
    Quote Originally Posted by Bikinfoolferlife
    well, blowing your tube/tire would stop you pretty fast.
    Jan 2005
    ProMax mechanical brakes are not very good but it's what ya gots. Check the cables and housing as suggested also fallow the instructions for set-up.
    http://www.leechi.com.tw/pdf/DSK810_MANUAL.pdf
    The Avid BB5's would be much better but if your aggressive the BB7 would be your best choice.
    http://www.spadout.com/b/Avid/mechan...-brake-system/
    Formotion Products
    http://www.formot
    Oct 2007
    My disc brakes are not stopping well at all.
    fixed for ya.
    do you get power on the lever and you're not stopping, or are the levers just pulling all the way to the bar?
    could be worn pads. could be they just need a bleed (or cable adjusted...didnt catch what kind of brake you have).
    most definitive way is just bring it to a bike shop and talk to a mech. not giving us enough information here, so it kind of limits what we can do for you.
