Results 1 to 7 of 7
    disc bend problem!!
    hi people. was cleaning my bike today and looked to the rear wheel and realised i have a bent disc rotor.
    is there anyway of straightening it without buying a new one??
    Sheffield,South Yorkshire
    Reputation: ibbo's Avatar
    I usually use an adjustable spanner,a hammer or a pair of pliers and a rag.
    Put a rag on the warped bit then either use pliers or spanner and just twist it back into shape,or take it off the wheel,wrap in a rag,lay on a hard flat surface and hit the bent bit with a hammer
    cheers mate. i have tryed to straighten my last disc but it went a little wrong . the disks i have on my bike now arent cheap in my eyes so i dont want to attempt to straighten them if i know what im doin (if that makes sense)
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    Quote Originally Posted by ibbo View Post
    Or instead of the ham fisted approach you could get a couple of these.
    Reputation: winter's Avatar
    It's similar to truing a wheel. First figure out what part of the rotor (wheel) is out of true and then bend it slightly in the opposite direction. I personally use a pair of CLEAN adjustable wrench and make small adjustments each time.
    Go on ahead, I'm gonna take a breather.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by lgoldie10 View Post
    It is not that tough to do
    rotor truing - YouTube
    mtbtires.com
    Mar 2012
    I usually just bend the out of true area back with an adjustable wrench (clean of dirt and oils). Not too hard though, and go in sections of the area.
