Results 1 to 13 of 13
Thread: disc adapters
    disc adapters
    Hi i have a 2003 diamondback xts with magura julies on it. I am looking to put bigger rotors on it(8inch). What adapter do i need, and where can i get them.
    thanks
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    are your calipers IS or postmount with adapters?
    i don't know. how can i check that.
    this is an IS caliper
    this is a postmount caliper (postmounts with an adapter can be mounted to IS mounts)
    you will need an adapter to increase the size, but the current rotor size and caliper style is needed to find the right adapter...
    EDIT: you could also post some pics of your current setup and we figure it out together
    thanks for the pics there very helpful. And it is a IS caliper
    And i have just standard, so 6" rotors
    I bike long tyme.
    Reputation: Secace's Avatar
    Sep 2004
    Flyingfischer5, Check your PM's.
    People wait for me on the way up. I wait for them on the way down.
    Quote Originally Posted by flyingfischer5
    then you nedd a +40mm IS-to-IS adapter to use 203mm brakes
    for example
    http://www.chainreactioncycles.com/M...px?ModelID=778
    http://www.chainreactioncycles.com/M...?ModelID=13746
    though I am almost sure magura makes one too..
    Can i use those adapters on the rear also too get an 8" rotor to fit? If not do you know of an adapter to do that?
    Those adapters work for any 160mm IS caliper, so they work on the back too..
    Is this the same type of adapter?
    http://cgi.ebay.com/Disc-Brake-Adapt...QQcmdZViewItem
    yeah.. that can get the job done
