Results 1 to 26 of 26
    Different Hayes 9 question
    Hey guys, yes I read the other post...
    just curious, can the brake be adjusted easily or no? Im picking up a new coiler this week and i remember noticing that the levers werent as tight as the ones on my dawg (same brakes)...can that be adjusted easily or do I have to have the shop do it?
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    There is a allen screw at the brass bushing that is a lever throw adjustor.
    Formotion Products
    http://www.formot
    Meh.
    Reputation: XSL_WiLL's Avatar
    It's actually a reach adjuster.
    Reputation: 006_007's Avatar
    when you say they are not as tight do you mean the lever is too far in/out or when you pull on the lever your old ones engaged more instantaneous?
    If in/out then what they said.
    if different engagement they might need a bleed.
    Jan 2005
    Formotion Products
    http://www.formot
    Meh.
    Quote Originally Posted by dogonfr
    The feeling is mutual.
    J/K man. How ya been?
    Quote Originally Posted by 006_007
    yea i mean that they dont engage as sonn in the pull as my dawg does...you have top pull the lever further before it does anything
    Jan 2005
    Hay i was just out in Indy this last week, friggin cold out there
    Formotion Products
    http://www.formot
    Get the shop to bleed em.
    Quote Originally Posted by AaronD
    Bleed may not be the issue.
    Take the simple route first. Look through the window of the caliper and pump the brake a few times. How's the retraction? Came across a couple of brakes on Konas that had a TON of retraction, causing the brake to have more throw than usual. Solution? Take the wheel out of the dropout and stroke the lever full once. Insert wheel, check feel of brake. Better? Excellent! Getting better but no there yet? Repeat above steps. Be sure to only give the lever one full stroke at a time though. Measure twice, cut once, right?
    Meh.
    Yeah, you can try to pump out the pistons a bit.
    Factory bleeds are usually pretty mediocre anyways. If the lever feels spongey, definitely bleed it.
    so whats involved with bleeding these brakes? ive always been told to just stay away from hydro brakes and let the shop deal with them, but at $50 per brake i donno..if its easy id like to know how to do it...im very mechanical, im a car guy so im not a clutz with this sort of thing..
    Jan 2005
    Get a bleed kit from your LBS, you can also pick up a syringe from the super market. The syringe is alot easier than the squeeze bottle but push the fluid through slowly.
    http://www.hayesdiscbrake.com/pdf/45...WebEnglish.pdf
    Formotion Products
    http://www.formot
    Mar 2006
    Wow, $50 per brake to bleed. I need to start a business. That would work out to $100-200 an hour if you take your time.
    Thunder Chunky
    Reputation: Madman133's Avatar
    $50 a bleed seems liek a rip off. I used a syringe like stated above instead of the squeeze bottle as i tried it with the bottle and decided it sucked and remembered i had a old syringe lying around...worked 100 times better...in all it cost me maybe 20 bucks max with fluid and the bleed kit and everything and for $20 you can do it more than once.
    Jan 2005
    Quote Originally Posted by Madman133
    i had a old syringe lying around....
    and why
    Formotion Products
    http://www.formot
    Thunder Chunky
    not the needle kind...it used to hold some kind of prescription cream i cant remember what for though cause i didnt use it.
    Jan 2005
    Kinda kinky
    Formotion Products
    http://www.formot
    Thunder Chunky
    Kinda kinky
    lol someone is going to use these quotes in the signature i can just tell lol i thinking about putting the syringe one in mine lol...sorry this is getting ot lol
    Jan 2005
    Formotion Products
    http://www.formot
    Flying Goat
    Reputation: mrpercussive's Avatar
    all this about syringes makes me think hentai... lol
    Jan 2005
    Quote Originally Posted by mrpercussive
    Syringes, mystery cream & hot anime sex.
    This is getting interesting.
    Formotion Products
    http://www.formot
    Thunder Chunky
    I'm going to make an amateur movie call brake threads gone wild and enter it into some film festivals lol
    Jan 2005
    You definatly need to get mrpercussive in it!!!! He can also edit the music for ya!!!
    Formotion Products
    http://www.formot
    Thunder Chunky
    hahahaha i definetly will hey mrpercussive can u draw anime too? lol...wow we have completely taken over this thread with our male minds
    Purple Popcorn
    Jan 2005
    Called the "Y" chrome syndrome
    Formotion Products
    http://www.formot
