    lvm
    lvm is offline
    Differences in Hayes Front vs. Rear?
    Is there a difference in the actual calipers to be used on the front and rear? I'm building a GIANT NRS and took an original model hydraulic Hayes off the front of my other bike to put on the rear (disc only). However, it seems that it doesn't line up properly. The frame mount would have to be about 1/2" forward for the caliper to line up on the rotor properly. I thought the only difference in the sets they sell was cable length, and also that this model doesn't have reversible levers/master cylinders.
    meh....
    Reputation: Monte's Avatar
    Quote Originally Posted by lvm
    The adapters are different, calipers are the same. Are you trying to move the adapter to the rear with the caliper? It won't work if you are.
    Monte
    lvm
    lvm is offline
    okay, cool. yes, i was using the same adapter. that's much cheaper than buying an entire new brake.
    thanks.
    lvm
    lvm is offline
    update
    well, i got the adapter, but i hit one snag. i'm using one of the older, original hayes disc brakes and apparently it's 68 or 70mm between holes in the mount. since the brake is fairly old i decided to drill it out to fit the 74mm adapter. so far so good.
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. 29er front, 26er rear?
    By sean350 in forum 29er Bikes
    Last Post: 09-06-2004, 01:10 AM
  3. opinions on 6" front 8" rear
    By ashayk in forum Brake Time
    Last Post: 06-25-2004, 01:59 PM
  4. Weight balancing front to rear?
    By keen in forum Weight Weenies
    Last Post: 04-25-2004, 09:00 PM
  5. rear tire vs. front tire
    By bike_riot in forum Wheels and Tires
    Last Post: 04-07-2004, 09:55 AM
