Results 1 to 10 of 10
    May 2005
    Difference between DOT 5 and 5.1??
    Avid recommend DOT 5.1 and I can get the DOT 5 at half the price in a car shop
    Reputation: vk45de's Avatar
    no dot 5 is not compatible. you can use dot 3 or 4 which are both water soluble.
    Meh.
    Reputation: XSL_WiLL's Avatar
    DOT 5 is silicone based. DOT 5.1 is glycol based. DO NOT use DOT 5.
    As the previous poster's have said, do not use DOT 5. It is a silicone based fluid that is not compatible with your brake system. My Elixers say DOT 4 or DOT 5.1 ONLY on the lever housings.
    Cheers, Brian
    squish is good
    Reputation: Clutchman83's Avatar
    DOT 5 will eat your seals (because it's silicone based). Use DOT 5.1.
    Bike good, work bad.
    Yep, they already said it. The silicone based started with Harley Davidson I believe. They wanted something that lasts without attracting moisture and eating paintwork.
    So DOT 5, silicone. DOT 5.1, the next generation of DOT 4. Stupid but that's the way it is.
    Oct 2007
    dot 5.1 is a marketing name for a little bit (marginally) better dot 4 fluid.
    Reputation: wyrm's Avatar
    If it hasn't been said before.... 5.1 is silicone base.
    hahahahahaha.....
    Could resist the redundancy.
    Bikeless Rider
    Quote Originally Posted by wyrm
    hahahahahaha.....
    lolol after all that, you still got it wrong. It's DOT 5 that's silicone based
    Doh!!!
    Bikeless Rider
