    Religion = Non-thinking
    Reputation: louisssss's Avatar
    Diff between Tektro Auriga Comp & Pro?
    What are the differences between the Tektro Auriga Comp and Pro models?
    and which model do they compare to on Avid's lineup?
    RH SL Pro
    Fart and Wet fart compared to Avids
    Reputation: Aresab's Avatar
    I believe the difference is in the levers as the calipers appear the same. They are not bad brakes, with different pads. The stock ones are not too good but since they use the Deore M525 pads, you have many choices. I used them at Diablo freeride park and I'm around 230lbs with a 180 mm rotor. They held up without issue. But to answer your question, they are lower-end brakes, more along the lines of a Juicy 3.
    initally, they behave pretty much like the J3s but (in my experiance anyway) the quality was pretty poor.
    i would put them on a kid's bike though (like under 10) cause they are REALLY cheap (cheap enough to be disposible IMO)
