Results 1 to 2 of 2
    uhhhh
    Reputation: RoDo's Avatar
    Did I boil my brake fluid?
    I ride a set of Hayes HFX Comp (plastic master cylinders) that are probably 4 years old. Today on a loooooong steep fireroad descent I was on the brakes for minutes at a time. I stopped to give my hands a quick break and when I started going again the levers pulled almost all the way to the bar with little braking effect. I was able to stop and then I pumped the levers and things went back to normal. This happened again when I stopped one other time.
    What's causing this? Did I boil the fluid? I don't remember the last time the brakes were bled, it was at least 1 year ago probably more.
    Thanks,
    -RD
    Quote Originally Posted by RoDo
    Thanks,
    -RD
    Had the same thing happen to my Hopes. When i pulled the master cylinder cover off there was solid brown "floaties" in there, I think the floaties temporarily clogged the check valve leaving the lever to just pump into the resevoir. I completely bled the system pumping all the old fluid out and haven't had the problem come back.
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. What is wrong with my front brake???!!!
    By BarfBike in forum Brake Time
    Last Post: 06-27-2005, 09:43 PM
  3. Big big big brake problem....
    By AdamOn6thStreet in forum Brake Time
    Last Post: 10-15-2004, 01:33 PM
  4. Which brake lever for which brake...?
    By mahgnillig in forum Brake Time
    Last Post: 10-06-2004, 02:18 PM
  5. brake fluids?
    By r1Gel in forum Brake Time
    Last Post: 08-10-2004, 06:39 AM
