Results 1 to 30 of 30
Thread: deore discs?
    Reputation: xisaacx's Avatar
    deore discs?
    hi
    does shimano deore mecanical disc are cool, or should i get another mech brakes?
    "El Whatever"
    Reputation: Warp's Avatar
    Rear Yes / Front No
    They are reliable and relatively heavy and easy to service. Modulation is very good when paired with Deore levers but if you want raw power the Hayez HMX-1 or the Avíd Mechs are the stuff.
    I have a bike with a Deore at the rear and a Avíd up front. I can rely on the rear under wet as it's very hard to block while giving a pile of stopping power. But I wouldn't put one up front, there's simply not enough power. Note that they are weak in comparison of an Avíd Mech but they are far better than Vee's.
    I guess the Hayes are in the same price ballpark but they have just more power. I don't know about modulation.
    Check my Site
    so,,
    so the hayes mx1 are better than the shimano, how about mx2?
    if i used to have vees, it would be a difference if i install deore mech disc front and rear.
    Reputation: Jaji's Avatar
    Quote Originally Posted by xisaacx
    i woudl get avid mechs b4 hayes. ive just never had a lot of luck with hayes. i know some people that like em, but its rare. avids i have only heard good things. ive tried avids too and they are the 5h1t for mechs.
    "El Whatever"
    Yes, there is difference...
    I haven't read or seen anything about the MX2 so I will not ditch or swear about them. But I think the MX1 is a bit more a better brake than the MX2. At least pads are tool-free adjustment. And yes they are overall better brakes than Deores but not for much. Here you get what you pay for.... Deores are the cheapest, but also the weakest (of discs!! Above from vees, remember!!). Next the Hayes, a bit more power but a bit more pricey. On top, the Avids.. but Avids are shoulder-to-shoulder with cheaper hydros even when Avids fry some hydros regarding power even if they do not have all the modulation a hydro can have.
    If you were used to the vees... you will hardly find a substancial difference between your old vees and the Deores until you find yourself in a compromised situation (when it counts!!). Deores have better modulation and all-weather performance. A bit more of power but as I said they are more dependable than vees under critical circumstances.
    Besides, if you dent or bend a rim you can still get home and even wait for you to have the bucks to replace the wheel.
    Go for Discs. The Deore goes very good at the rear. Get a Deore at the back and a MX-1 on the front if your budget is pretty tight. The full Deore is a good option too but it will leave you wanting for more.
    Check my Site
    what do you mean by ...
    they are more dependable than vees under critical circumstances?
    "El Whatever"
    NOT TO OFFEND anyone...
    But I guess that xisaacx is on a very tight budget Jaji.
    I feel that way 'cos I went thru it when I first went discs. I couldn't afford a set of Avids and finally went for Deores even knowing Avids were the stuff.
    For a set of Deores you gotta spend like 150 bucks plus installation (discs+hubs+lacing+etc). For a set of Avids that would go for 250 plus installation. It may sound like little money but for someone studying or depending from his parents or beggining in the sport may be like too much. It was for me.
    OTOH, Hayes are just like 10-20 bucks more than deores and the difference is good for the money.
    You gotta take into account the cost of the bike. If he spent 400 or 500 on his bike, he'd probably want to keep upgrades in the reasonable side. 250 bucks for mechs are like the half of the cost of the bike. Not an option IMHO.
    As I said, this is how I felt when I went thru it. Hope it helps.
    Check my Site
    "El Whatever"
    I meant...
    That while your vees pads were struggling under the rain to get a grip on the rim, the discs still work with a lillte innuendo to your lever.
    When you need to brake and not block the wheel (say you're at 30mph down a steep hill and the end is loose-over-hardpack and a +90° turn is at sight) the discs are there to provide you with more decceleration power AND less chances for your wheels to skid over and you to fall.
    Discs are plain better under wet, loose and emergency situations.
    Check my Site
    i´ll have to save more
    i think i´m gonna save a little more to get the avids or maybe magura julie to go hydro.
    i don want to buy another brake set next year because they wasn´t what i expected.
    does the magura julie are better than the deore hydro? or just the same?
    "El Whatever"
    Good decision....
    wait for some replies on the other question you made as I haven't used any hydro. Any response from me will be useless regarding that.
    OTOH, not anything will be money wasted... hubs will be the same for hydros/mechs. You can start by getting the hubs and getting your wheels relaced.
    The Julies look like features loaded but I've read Maguras are a bit harder to set-up than the rest of the pack. In fact I was thinking about going hydro but I'd rather ride my Avids 'till they die. Deores look good too but a bit pricey??
    Good luck!!
    Check my Site
    Born of Fire
    Reputation: pufdup's Avatar
    The Maguras I've seen haven't been dependable. If you can swing it get deore hydros. They don't get any easier.
    Auto-x addict
    Reputation: VpointVick's Avatar
    I don't want to knock the Maguras, because I have not ridden them, but I have heard that they can be somewhat finicky. Perhaps not the best choice for the first time disc brake user.
    Can you get the Hayes hydros in your country? HFX-9 is a great brake, easy to set up and rock solid reliable, about the same price range as the Julies also.
    hayes
    so, do you recommend hayes hfx-9 over the deore hydros. there are dealers for both systems in my country.
    "El Whatever"
    No habia notado que eres de Mexico....
    Yo tambien.
    Si estas en la capital, date una vuelta por Viansi en polanco. Ellos distribuyen Hayes y Magura.
    Por los Deore, date una vuelta por cualquier Benotto de San Pablo. No he preguntado precio de frenos Hidraulicos Shimano, pero deben de estar en la misma escala.
    En USA deben ser un poquito mas caros que los Hayes o Magura, pero aca es diferente.
    Un Abrazo!!!
    Check my Site
    mex
    Quote Originally Posted by Warp2003
    Yo tambien.
    Un Abrazo!!!
    de hecho vivo en guadalajara, ya pregunte en viansi por los magura y los hayes, y por los shimano tambien el precio es muy similar de los 3 los magura 1350, los hayes 1200 y los deore 1600 aprox. (3900 el par. masas, rotor caliper y lever)
    por cuales me voy, como notaste soy nuevo en esto de los frenos de disco.
    to warp2003
    sabes donde puedo encontrar avid en mexico?.
    "El Whatever"
    xisaacx
    Avid en Mexico solo consigues en Estados Unidos.....
    De hecho. Yo tengo tres frenos Avid (uno que compre y los dos de mi Giant Warp DS1 '03)y no he podido conseguir rotores en ninguna parte, porque tengo uno que esta muy doblado.
    Si quieres balatas de freno Avid, las puedes conseguir en Transvisionbike. Visita su pagina y llama a la sucursal de Satelite porque no estan en su catalogo en linea. De hecho, pregunta ahi por los Deore, chance esten mas baratos.
    Yo tengo pensado ir el sabado a Transvision de Satelite. Dejame preguntarte que opciones tienen.
    Check my Site
    "El Whatever"
    No te quiebres el coco....
    Consiguete dos mazas Deore de disco (que aca en el Defectuoso deben andar por 450 max). y los Hayez de 1200. En total serian 2800 o 3000 max. y los Hayez son buenisimos. De hecho yo voy a comprar un rotor Hayez para mis Avid pues no encuentro repuestos. Incluso estaba pensando en un Magura.
    Puedes preguntar tambien en Benotto por los Shimano. Me parece que todo lo Shimano en Mexico lo mueve Benotto, asi que posiblemente tengan mejores precios. Ve a su pagina y consiguete el telefono de alguna de sus tiendas en San Pablo y pregunta.
    Yo no tengo pensado ir al centro pues se me hace medio complicado, pero podria ir la semana entrante.
    Check my Site
    gracias
    gracias es buena opcion,
    por las masas de hecho pensaba cambiarlas, instale o no los discos asi que mejor de una vez le pongop masas para disco y junto para los hayes.
    Auto-x addict
    If your budget is VERY tight I would say get the Deore hydros. I've ridden them, and found them to be about as good as my Avid mechanicals.
    That being said, if you can afford to save a little bit more money and get the Hayes HFX-9s, I think you will be much happier in the long run. They are not that much more money than the Deores, but have better braking power, and MUCH better modulation.
    If I were in your spot, with availability of the Avids difficult, I would save my money and get the Hayes hydros.
    hayes $$
    actually hayes hfx-9 are cheeper than the deores 555.
    i´ll get those, i have read some good posts and reviews. except for the levers. are they so bad?
    Auto-x addict
    I've test ridden 2 of my buddies bikes, and a long ride on a rental bike, that had those brakes, and I didn't notice anything too terrible about the levers. My full susp. bike has the HFX-Mag plus with the carbon levers and they're fantastic. It must be one of those personal taste deals. :0)
    Reputation: Schtoojp's Avatar
    Uhh...
    Deore mechanical discs? Great in the dry, not so good in the wet. The pads don't like getting wet, but they will still work quite well.
    Abid? Great, wonderful, fantastic, perfect. If you can swing the extra few bucks for them you will not regret it.
    Hayez mechs? Friends don't let friends use Hayez mechanical brakes. Ever.
    Even if you find the Hayez at $20 a set, they are just not worth the hassle and grief. The Deore is a far superior brake, to the point that the newest Hayez mech brakes are remarkable in that they look nearly identical to the Deores... Must be a reason for that.
    Yes, used them all for over 6 months each and at both front and rear ends. Hayez no, all others yes.
    hayes.....
    i didn´t realize thath hayes mevh were so bad, i expected a better quality as the hydros.
    does shimano deore mech are bad in wet as the v-brakes? or do they perform better?
    what about mudy terrain?
    "El Whatever"
    Yes, they are....
    Yes, Deore Mechs are far better than vees on the wet and muddy. I rode yesterday with a friend of mine who rides a Deore Mech on the rear and it was pretty muddy but not so wet. I've used them on both situations and they are far better. Any disc is far better than a vee when things go ugly.
    Check my Site
    The Hayez mechs are worse than you expect. I've not used the hydros myself, and there is very little reason for me to bother with them either (as I have heard and seen how ugly they are. Cannot work out why people like them...)
    Anyway, the porblem with the Deore disc brakes is that the pads are non-metallic resin. Pick up a Hayez pad (about the only good part of the brakes) and you will notice the thing is copper/brass coloured. That's because the pad has heaps of copper/brass in it! All that metal bites into the rotor, which means the brakes will still stop PDQ even if the whole thing is underwater.
    The Deore pads are mostly a green/grey colour. Very little metal in there. And unfortunately that resin seems to behave like a sponge for water. Also, the lack of hard material in the pads means they have little ability to bite into the rotor. So you have a twofold problem of the pad being unable to bite into a wet rotor, plus it has to boil off any water it has absorbed. Sounds bad, but in reality it's not quite as bad as it sounds.
    What you get is a brake that when dry is super smooth and very progressive with great modulation AND amazing braking power. To be honest, I like them much better than the A vids I have on now, in the dry. The A's are a little grabby and noisy and 'crunchy' .
    In the wet, the Deore are as unpredictable as a V-brake when they have gotten wet. You get that complete lack of braking, then it starts to come in and then it works well. So while you have a fist full of brake (while it's not working) it starts to really stop well, but you still have a fist full 'o' brake, so the wheel wants to lock up. Pretty interesting... Having said all that, the discs are still superior to a V-brake in most cases.
    If you can't swing the cash for A vids, then the Deore is a good choice, especially at around half the price...
    Schtoojp. pretty good...
    explanation. thanks.
    is there any replacement for the deore pads, i mean a semi metallic replacement pad that makes deore´s works better than they do on wet terrains?
    if not maybe i´ll try deore mech disc, as i cant get any avids in this country.
    what about the deore disc hubs, are they ok or i look for another disc hubs?
    thanx again
    "If the pain doesn´t kill you... it only makes you stronger"
    "El Whatever"
    Fribax P/N ASH 991S...
    Fibrax make some sintered pads for Deores. You can get those at Transvisionbike at Mexico City (at least the normal resin ones).
    EBC Golds P/N CFA327 are sintered too.
    Just be aware... newer Shimano rotors have a huge inscription saying "RESIN PADS ONLY". I don't know about the originals and I guess is sort of a problem with the steel used for the rotors but Schtoojp has more acces to Shitmano gurus so he can bring some light regarding the use of sintered pads on Deore rotors. Maybe the sintered pads are not good as the rotor has very few holes so pads are not properly scraped or something.
    But that is easily solved if you use some Hayez rotors (250 a piece at Viansi).
    Check my Site
    "El Whatever"
    Sorry.....
    You were asking for Semi-Metallic... I mentioned Sintered.
    Anyway... Fibrax makes some composite (kind of organic) pads and you can get them at Mexico City and you can use them on Deore rotors. Here's a review I found.
    "Fibrax Disc Brake Pads Review
    Author: Eno
    Product Courtesy of Klimax Imports
    SRP: SGD35 for sintered version
    SDG32 for HPC version
    Availibility: Now
    The pads of a disc brake are a crucial component to the performance of the entire braking system. So much so that they can either make or break a disc brake system. Disc pad material's friction coefficient forms an integral part of the equation which determines total braking power and initial bite. Its hardness determines its longevity and mud performance. Squealing noise can sometimes be due to brake pad compound as well.
    Generally disc brake pad materials can be distinguished into 3 types: Metallic or sintered metal, organic compound or metallic-organic mix. Fibrax offers two versions of disc brake pads: Sintered Metal or organic ( HPC-High performance compound ). The HPC is used for all purpose riding, i.e. XC conditions. On the other hand, the Sintered Metal compound is used for absolute braking power, or when it needs to break through muddy conditions.
    We were offered HPC disc pads for testing on an XT disc brake system. Pads come in a pair with a brass spring and a Fibrax sticker ( Cool! ). Installation wasn't a problem. ( Sometimes, aftermarket pads are cut wrongly and can't fit the calipers of the system it is intended for. ) The brass spring was slightly wider than stock springs, thus providing a stronger spring to push back the pistons and hold the pads in place. This would also aid in reducing any noise due to pad vibration. However, the arms of the brass spring are quite brittle and care needs to be taken during installation least the arms break off.
    Performance
    Performance differences would vary when used in different disc brake systems, i.e. Hayes, Hope, Magura etc. Also, changing between metallic pads and organic pads itself would make a world of difference. For our test, we compared organic XT pads to the HPC ones.
    The break-in period wasn't excessively long. Especially since these were non-metallic pads which normally take almost no time at all to break in. The contact point felt slightly better than when using stock pads with an initial bite that was gentle and non-grabby, yet distinct. This makes it great for XC applications where the rider's weight is so far forward its easy to endo whilst braking on a steep downslope. It also makes a great upgrade for some disc brake systems which are very grabby ( or on-off ). On the XTs, it made braking more subtle and gentle without sacrificing stopping power.
    Maximum braking power was sufficient for most XC applications. As long as it isn't a heavy freeride/ DH bike, there is enough stopping power available. There wasn't much heat generated on long, braking descents to compromise braking performance. At no time during testing was brake fade experienced. However, after a few weeks of testing, the rear brake started to emit scraping noises during braking. This is a common phenomenon to disc brakes, though, and a very minor thing easily solved by frequent cleaning with ethanol or disc brake cleaners.
    Wet weather performance was where Fibrax pads show their worth. Unlike most other disc brake pads, there was totally no difference in braking feel and power when dry or wet! This was a surprising find. On stock XT pads, there is a slight loss in braking power when riding in the rain when the the disc and pads are wet. Not so for the Fibrax pads. This makes wet weather riding safer since the feel and power remain the same as in normal ( dry ) conditions.
    Conclusion
    There are 2 common reasons for people to want to change their disc pads: 1) Their stock disc pads have worn out. 2) The stock disc pads are problematic in some way. Whatever the reasons, Fibrax disc pads are a definite viable aftermarket option. Compared to most organic stock pads, they would offer equal, if not higher performance. Wet weather performance is where it is exceptional, although it would also make the brakes modulate better.
    Besides Shimano disc pads, Fibrax also makes disc brake pads for a whole host of disc brake brands besides. E.g. Formula, Magura, Hope, Diatech, Avid etc etc. The brand also produces other parts like V-brake pads and cables.
    Fibrax products are available through most leading bike shops. Seng Chu Hin, in particular, carry a pretty large range."
    Schtoojp: Can you guess why the Shimano rotors can not be used with sintered pads (at least Deores and lower end)??
    **** edit **** I guess Koolstop pads are semi-metallic and they make a model for the Shimano Deores.
    Check my Site
    "El Whatever"
    For the Deore hubs...
    They work pretty well.... I have four of them and only one has needed some service. Two of them have now 1600km and no service needed at all.
    If you can lay out like a thousand pesos get the XT hubs. It's almost impossible to get just one hub. Those are sold by set.
    As the Deore axles are famous for breaking or bending (they use the same axle for the disc and non-disc versions) the right combo should be a XT Front/ Deore Rear but you have to go from full Deore to full XT thanks to Mexican Bike stores not selling hubs by the piece. I already went thru it trying to find parts for the deore hub that needed service (Axle, cones and balls). Actually I couldn't get the Shitmano spares but a miserable 18 pesos axle is giving a happy service inside my Deore hub now.
    I would strongly recommend the Deores if you can't afford the XT's.
    Check my Site
  1. Changing pads (Deore discs)
    By Trail Punk in forum Brake Time
    Last Post: 06-04-2004, 09:48 AM
  2. Deore Discs + Rain = Squealing
    By eighty in forum Brake Time
    Last Post: 05-04-2004, 09:58 PM
  3. Late 80's- Did XTR exist?- what is "Deore" ?
    By mojo in forum Vintage, Retro, Classic
    Last Post: 03-30-2004, 10:31 AM
  4. deore discs
    By dompedro3 in forum Wheels and Tires
    Last Post: 03-26-2004, 04:25 PM
  5. Problems with Deore Discs
    By cowleyd in forum Brake Time
    Last Post: 01-26-2004, 09:57 AM
