Results 1 to 10 of 10
    Mar 2006
    are deore disc brakes better than tekro v brakes?
    I received an old front Deore disc brake. I need to buy an adaptor to mount it on my Manitou Axel fork. Should I spend the money to buy an adaptor, or is my Tekro v-brake going to perform better? The Deore disc brake looks to be about 3 years old, it's mechanical.
    Thanks,
    Michael
    Yes, the disc should perform better if it is in good shape.
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    It's a decent disc
    There are two versions of the Deore mechanical. The BR M515 and the BR M515LA. The LA designation stands for "Long Arm" which indicates that the arm that engages the calipers is longer and provides more leverage when you squeeze the brake lever. I have a set on my Ibex and they are very good. I would venture to guess that even if you don't have the LA version, they'll perform much better than the tektro V brakes. Had them too, and while they are OK, they certainly don't perform as well as my Deore mechanicals.
    Buy the adaptor, mount it and ride.
    Bob
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    Meh.
    Reputation: XSL_WiLL's Avatar
    It'll be worth it.
    Mar 2006
    Thanks for the replies. I'll hit up the LBS's tomorrow and see if they have the adaptor.
    Mar 2006
    I called my LBS and the guy looked something up and said that there is no adaptor for the Shimano Deore to Manitou Axel fork (I think it's IS). Can anyone verify this?
    Meh.
    If it's IS caliper to Post Mount fork, you have to go up in rotor size for the adapter.
    Mar 2006
    Can someone please show me exactly where to get the adapter and which one I need? I've been searching on google all day and I'm still confused! Thanks
    Michael
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    You need an adapter like this
    And you can get it here
    http://www.discbrakeadapters.com/fs_....php?item_id=6
    I hope this helps,
    Cris
    Mar 2006
    Quote Originally Posted by crisillo
    I hope this helps,
    Cris
    Thanks a lot, that's exactly what I need.
