Results 1 to 7 of 7
    Reputation: Fly2Hi96's Avatar
    Cutting Hydraulic Hose
    I need to shorten the lines on my Ouro Puros. What is the best tool, other than the suggested Formula tool, to cut the hose.
    A Member
    I would like to know to, used a fencing tool for some 'bullet proof' gear housing but guessing it would not be neat enough for brake hose.
    Reputation: monkies's Avatar
    i have the oro k24s..i went to pricepoint and ordered a cable houring/cable cutter for like $10. that was fine...i do remember that when i first cut that the cut wasn't totally flat but an angle because of the blade angles...so cut above where u want to cut to make sure u know how ur blade cuts.
    other than that it was a piece of cake (including the post cut semi-bleed steps), even for me and i'm a tech reject.
    ...idios...
    Reputation: SteveUK's Avatar
    Is this any help to you?
    Diogenes
    A Member
    Quote Originally Posted by SteveUK
    Thank you very much, and crapaccount will look into the tool
    Wow that's nice work.
    wyrd bi ful rd
    Reputation: chinaman's Avatar
    I used my standard electrical wire cutter (not the small ones; the ones where the cut is actually perpendicular to the grip) ... work alright.
