Results 1 to 5 of 5
    Cutting Hope SS brake line
    Hi,
    I purchased a set of Hope Tech V2's for a build and after mounting the brakes I noticed the the rear line was about 20cm too long. I went to hopes website watched a few videos, but the video's were a little vague and I'm still green as far as building goes. My first question.
    What is the ideal length for brake lines/cables on a freeride hardtail?
    What is the best way to cut Stainless line? Would a park CN-10 work?
    Can the compression olive and needle on the existing line be reused or do I have to purchase a kit?
    You will need a new olive and insert. Standard cable/outer cutters work fine.
    Cable length is all about having enough but keeping it clean. Check out some pictures of finished hardtails in the AM forum to get a visual.
    Pivoteer
    Reputation: tiSS'er's Avatar
    You can reuse the olive and needle on Hope kits, no need for a new one. I used Park cable cutters. Nice and clean.
    Employed by Pivot Cycles - www.pivotcycles.com
    What tool should I be using to compress the olive?
    Just use a pair of needle nose with the ends taped and lightly squeeze. Tightening the nut will compress the rest. Just be careful not to gouge the olive while removing or instaling.
    High Ho Sultan, Lets GO
