cure for brake squeal
Printable View
  • 11-28-2012
    kneejerk
    I have two sets of wheels one with 6 bolt discs and the other with center lock discs. I noticed more brake squeal with the 6 bolt discs by far, actually the center locks are very very quiet... don't think they have squealed on me at all.
    So, I tried putting some zip ties on my rear rotor to try and dampen the noise and it seems to have worked brilliantly. Anyone else try this? (attached pic shows three black zip ties on spider of brake rotor). Not all rotor designs are going to accomodate this... these are Shimano rotors I'm using with my Hayes Stroker Ryde calipers. I didn't bother doing this to the front, as I have not had the same kind of squeal issues there.
  • 11-28-2012
    SB Trails
    Kj---what a great idea.. I can see where this this would work great..2 attaboys and 1 good job for thinking outside the box...:thumbsup:
  • 11-28-2012
    zarr
    i hear swiss stop pads are good.
  • 11-29-2012
    kneejerk
    just send all royalties to my paypal account! ;)
  • 11-29-2012
    bulerias
    What's the melting point of a zip tie? Or is this just a winter fix? Seriously, maybe there would be a market for a more elegant 'product' that would take the inevitable glowing rotor descent. Of course, the one size fits all aspect of the zip tie is hard to better.
  • 11-29-2012
    RobinGB
    im trying to figure out why 3 zipties would cut down on squeal... added stability vs vibration?
  • 11-29-2012
    kneejerk
    I doubt I will ever heat them to more than a hundred degrees F. Although you bring up a good point. They probably start to melt around 250 degrees F. (I imagine)
  • 11-29-2012
    kneejerk
    it dampens the vibration, similar to holding your hand onto a drummers symbol stops the sound
  • 11-29-2012
    RobinGB
    that it im heading down to zipped mine.... lets see how well this works.
    avid elixer 5's squeal like hell when wet, and its been piss'in for days.
    now did you physically remove the rotors get enough tension in the zipties?.
  • 11-29-2012
    LWright
    I have tried reflective tape with limited success, might try the zipps although keeping pads and rotors clean between rides has worked the best so far.
    To get zipps good and snug I use a cable puller!
  • 11-29-2012
    shehateme
    I am doing this now!
  • 11-30-2012
    Procter
    Genius, trying this for my next ride, whenever it stops pouring in CA
  • 11-30-2012
    Eville140
    Bump'n for updates. My elixer 5's squall like crazy.
  • 11-30-2012
    RobinGB
    Day 1 with my elixer 5's , no change under extreme wet conditions. I think the way the avid brake rotors are made make it unlikely this will help.
    Hopefully i can get a dry ride in on sunday and see what happens. err hear rather. lol
  • 11-30-2012
    HitmenOnlyInc
    I have some Elixir 3 that squeal bad. I am gonna try this tomorrow!
  • 12-01-2012
    kneejerk
    if you continue to have "squeal" problems you can always switch to an "organic" pad compound or a rotor with an "aluminum carrier"... both of those options should also minimize the vibes (I imagine)
    I clean my bikes pretty regularly with a "bike wash" solution (Pedros or Finish Line)... which makes the brake performance deminish for a while afterward, sometimes even with some Wooooe!... momemts on the first few downhill applications... but the stuff burns off after a few of those and normal braking performance returns.
    I actually changed out my original brake pads on these same brakes because they squealed so bad it bugged me (Hayes Stroker Ryde)... and since I found this zip tie trick was able to go back to the original pads w/o squeal. If you can't get a zip tie to extend across a decent distance of the rotor it may not be effective. Also, I didn't pull them very tight as someone else mentioned, I just did the zip ties as tight as I could by hand and rotated the ends to where they would not hit anything.
  • 12-01-2012
    RobinGB
    I keep meaning to jump over to organic pads, but no one carries them and i never think ahead to order them.
    I really need to research out a rotor that sheds water though, 90% of my squeal is due to wet muddy conditions.
  • 12-01-2012
    Learux
    Formula brakes, organic compound quite noisy, switched to sintered, have not heard them since.
  • 12-02-2012
    kneejerk
    I guess going with a "softer" compound is what I meant by getting a quieter pad. Maybe there are "organic" compound pads out there that wear slower than a "metal" pad. Just going from brand to brand can bring changes in "noise" or performance.
  • 12-02-2012
    RobinGB
    trail day 1,
    spent more time swimming then riding, super wet rotors soaked the whole way down. I guess we will see what next week brings.
  • 12-21-2012
    Billinsd
    Any updates?
  • 12-21-2012
    MitchD
    I developed a squeel when I changed wheelsets. I thought no way so I put my old wheels back on and no noise.Hmmm, same rotors,same pads one makes noise and one doesnt? My next step was to put rubber grommets in the smaller openings in the rotors and no more noise,quess the grommets are soaking up the vibrations?I think this is on the same concept as the original poster with zip ties
  • 12-21-2012
    wschruba
    It would be difficult to find an organic/non-metallic pad that wears as well as sintered metal. Someone feel free to jump in if you know of one.
    Mitch: do you mean you spaced the rotor away from the wheel with the grommets, or put them under the bolt head, on the outside of the rotor?
  • 12-21-2012
    axisofoil
    225C, or 437F. Most quality zip-ties are made from nylon 6,6.
  • 12-21-2012
    kcvpr
    Brake squeal has more to do with improper brake bed in procedure than whether or not you use zipties for their supposed vibration dampening properties.
    Improper brake bedding causes microscopic 'hills and valleys' in the rotor and pads to form from the bedding layer of the brake pad not being evenly distributed on the rotor. This is why if you actually read the manual to your brakes they tell you not to lock up the brakes when breaking them in.
    When you improperly bed in your brakes you are basically turning your brakes into a phonograph. The rotor being the record and the pad being the needle.
  • 12-22-2012
    MitchD
    No the grommets are in the windows of the rotor,not as spacers
  • 12-22-2012
    bruce219
    This is so true,i read all the time about people bedding there brakes in on a ride,disaster straight away,you have to bed brakes in proper and let them FULLY COOL DOWN.I have the xo trail brakes that a lot of people ***** about,i think there great brakes,no brake squeal because i bedded them in proper.Zip ties,e.t.c are only band aids.
  • 12-23-2012
    MTBeing
    Looks like SRAM agrees with you. From their Hydraulic Brake Overview:
    "Brake pads and friction
    Brake pads function on two principles: adherent friction and abrasive friction.
    Adherent friction begins with depositing a thin transfer layer of pad material on the rotor during an initial burnishing, or bed-in
    procedure. Once this layer is established, applying the brakes creates molecular bonds between the pads and the transfer layer on the
    rotor that are instantaneously established and then immediately broken, providing friction. Proper bed-in is absolutely critical to braking
    performance, as an uneven layer of pad material on the rotor can cause excessive noise and uneven braking. This may be imperceptible
    at first, but as the layer continues to build unevenly, these issues could arise after several rides.
    Adherent friction is the primary
    contributor to overall braking friction, and pad material is the key component in creating adherent friction. This is why pads wear much
    quicker than rotors."
    I'm definitely going to bed properly upon receipt of my new bike.
  • 12-23-2012
    zarr
    I read and kind of understand, but how do you PROPERLY bed in your brakes? Just by waiting for them to settle in? Does the squeal just go away after a while?
  • 12-23-2012
    kcvpr
    That's a very good idea, but probably not possible if your bike has been test ridden before like most bikes have when they sit in a bike shop for more than a few days. Because any bike shop that knows or cares about what they are doing will test ride every bike they do labor on, whether its new or old (like the shop I work at for example). The bed in procedure is not always done, or at least not all the way. As most bike shop mechanics dont have time to test ride a bike for 20-30min to properly bed in the brakes. This is further complicated by joe plumber who just jumps on the bike and grabs handfulls of the brakes whilly nilly.
    The bed in procedure is something that should have been done when the brakes where new. The process is usually outlined in the owner's manual. But consists of several smooth but not complete stops from certain speeds repeatedly.
  • 12-23-2012
    Zoke2
    If all else fails try Squeal Out
  • 12-23-2012
    Kaizmuth
    So if they aren't bedded correctly and the adherent layer isn't properly laid down on the rotor, couldn't you just clean the crap out of the rotor then rebed them properly? That way you build a new adherent layer with proper bedding.
    Am I wrong in thinking this?
  • 12-23-2012
    bruce219
    Take the pads out and give them a even sanding as they would be glazed from an improper bedding,and clean the rotor,might work
  • 12-24-2012
    chrisem
    Kaizmuth, you're right to a point. Just cleaning them won't get the pad material out of the steel, though. The rotor needs to be sanded to get a new surface. A random orbit sander with 150 - 180 grit paper works well. Just the braking surface needs to be done. Do as Bruce said with the pads, but do them on a flat surface by hand.
    Magura has a good description of how to bed in brakes on their site.
  • 12-24-2012
    Ufdah
    I don't want to belittle any of the benefits of proper bedding because it sounds like there might be something there, but to "fix" brake squeal the OP and the one who put grommets in the holes to stop it were pretty wise. The reason brakes squeal is that the friction between pads and rotor cause the rotor to vibrate. If the vibrations happen around the resonant frequency of the rotors it causes the entire rotor to turn into a big speaker, exact same phenomenon as making a wine glass "sing" by rubbing its rim with a damp finger. One of the easiest ways to fix this is to change the resonant frequency of the rotor or dampen its vibrations, like wrapping duct rape around a wine glass, it won't sing any more. This can be done by either adding mass to the rotor (which will lower the frequency of the squeal) or add damping material which will help eliminate resonant vibrations.
    All that to say, if you have used brakes that squeal and are satisfied with their performance, just not the noise, try zip ties, grommets, etc. Otherwise sanded rotors and pads with a proper bedding procedure may work too.
  • 12-25-2012
    Kaizmuth
    Chrisem, if the rotors were properly bedded and working well with a good layer of pad material adhered to them, why would you need to rebed then if you are just switching pads? I understand that they won't be perfectly matched like the old ones, but that adherent layer is already there. Why wouldn't that just start working correctly right off? I can see some layer thickness difference from the new pads not matching up perfectly, but I'd think they would still work better than a new or clean rotor.
    I'm just trying to fully understand the logic behind the process here.
  • 12-26-2012
    kcvpr
    Because the new pads have a fresh layer of bed in material you have to burn through... And it never hurts to do things properly. ;)
  • 12-26-2012
    chrisem
    Kaizmuth, if they're bedded in and working well, you won't need to do anything to the rotor, or go through the bedding in process.
    If they weren't bedded in properly from new, then it's unlikely that the brake pad material has adhered evenly right around the rotor. It will be patchy with high and low points.This can cause vibration/squealing, affect modulation and reduce performance. Putting in new pads with a rotor like this, will just lead to the high spots getting higher, and the dreaded and embarrassing squeal will still be there.
    I was recommending sanding the rotors only if you are having these sorts of problems.
  • 12-26-2012
    Bill in Houston
    So, I tried putting some zip ties on my rear rotor to try and dampen the noise and it seems to have worked brilliantly. .
    well done, kneejerk. when i ued to machine brake rotors and drums, we would use a rubber dampening strip to accomplish what you have done there. like Ufdah said, the resonance in a squealing rotor like a singing wine glass.
  • 12-28-2012
    EUREMA
    i too had squeal that sounds like pigs being slaughtered! tried so many other ways but the squeal (turkey gobble) will return after a while......
    finally saw this post and tried your "zip tie mod" and works great! thanks a lot for this amazing tip!
    it even quiet down wet rotors! (i live in tropics and monsoon season is helluva wet and muddy here)
    awesome!
  • 12-31-2012
    ninjamunky
    Interesting thread. Glad to know I'm not the only one with brakes that squeal like crazy. Mine only do it when wet, but it's really annoying.
  • 12-31-2012
    MTBeing
    Bed-in Procedure
    From the Elixir Service manual:
    To safely achieve optimal results, remain seated on the bike during the entire bed-in procedure.
    1. Accelerate the bike to a moderate speed, then firmly apply the brakes until you are at walking speed. Repeat approximately twenty times.
    2. Accelerate the bike to a faster speed. Then very firmly apply the brakes until you are at walking speed. Repeat approximately ten times.
    IMPORTANT:
    Do not lock up the wheels at any point during the bed-in procedure.
    3. Allow the brakes to cool prior to any additional riding.
  • 12-31-2012
    kikoraa
    Zip tie idea is fantastic! Even of it does melt o doubt it will do any harm. My rear squeals too. Can't wait to try this tonight! I'll give rep when I get home. Count on that!
  • 01-01-2013
    Bikin Fool
    Putting the brakes to bed
    I'm really liking the idea of the zips. Although proper brake bedding is desirable, in the arena of mt. bikin' it seems unlikely that the rotors and pads will get anything but ground down to smithereens anyway, bedding or no bedding. I suspect that proper bedding will give you good brakes for a couple of rides, after that all bets off.
    P.S. I've had most of my brake issues with Avid's.
  • 01-01-2013
    ferros
    Or just buy some Shimano brakes.
    OP Great tip with the zip ties. I have a set of formula rotors which squeal. I'll have to try this.
  • 01-03-2013
    Bikin Fool
    Bye, bye Avid's
    Just took delivery of new XT's
  • 01-03-2013
    bruce219
    Glazed pads will make your rotor sound like a record player,
  • 01-09-2013
    shekky
    uh oh. i think i only did this fifteen times today with my new pads...
    and i think i only did this five times, maybe seven...
    i didn't lock the brakes during the process, though. (front brake, who wants to do that?) i was also sure to let them cool for about an hour. there was still a minimal amount of squeal but so far, so good.
  • 01-09-2013
    Bill in Houston
    I hear ya. I applied the brakes firmly ,i think, but perhaps not firmly enough, in step 1. then for step 2, i couldn't remember the instructions,so i applied the brakes quite firmly, rather than very firmly. have i ruined this set of pads?
  • 01-09-2013
    kcvpr
    I wouldn't worry about it.
