Results 1 to 2 of 2
    CB of the East
    Reputation: bedwards1000's Avatar
    Cross (Interrupter) Lever Fit
    I want to add interrupter levers to my cross bike with standard 25.4mm clamp drop handlebars. Tektro has some that seem fine for my needs but they only offer them in 24mm and 26mm. This seems to be the norm. Should I go smaller which will give me 1mm of clamping or bigger with shims. I've seen both recommended.
    Reputation: grandsalmon's Avatar
    I have some tektro cross tops, work fine with shim from 31.8 to 25.4(26)- little extra space to make up the diff.
    Then I put some Salsa's on my GF bike, and her levers are a bit nicer in many respects; ergo drilled grip, NICE finish and works well/tight. They are also shimmed from 31.8 down to 25.4 using the 26 supplied. I was just jealous- they are $29 first look, in the Tektro price range. Same price as my Tektro linear top (interrupter) pulls I'm getting.
    Good luck
    went off tangent a bit; to you, one or two laps of Gorilla tape to width should make a good 26- if need.
  1. Surly Cross Check vs. On-One Il Pompino
    By SpinWheelz in forum 29er Bikes
    Last Post: 05-19-2010, 01:57 PM
  2. 2007 Jamis Prices
    By sims in forum Jamis
    Last Post: 10-18-2006, 08:31 AM
  3. Whiskeytown Cross-Country, Cal State Series, Sept. 23
    By Bigfoot in forum California - Norcal
    Last Post: 10-02-2006, 06:23 PM
  4. Will the cross check fit the big apple?
    By Fastskiguy in forum 29er Bikes
    Last Post: 04-13-2006, 11:52 AM
  5. Surly Cross Check vs. On-One Il Pompino (x-post)
    By SpinWheelz in forum Singlespeed
    Last Post: 04-05-2005, 05:34 PM
