Results 1 to 2 of 2
    Reputation: cubeman's Avatar
    Dec 2004
    Converting a Shimano lever to 90 deg
    I'm looking for a way to convert my Shimano M756 levers that have a straight fitting to be used with a 90 deg fitting.
    This because I use a Jones H-bar and a 90 deg banjo would give me an optimal cable routing.
    Is it possible to use a 90 deg banjo on a Shimano M756 lever?
    Meh.
    Reputation: XSL_WiLL's Avatar
    If you root through a Shimano small parts kit, you might be able to throw something together. I don't have a definitive answer though... sorry. If you can source the fittings, it will work.
