Results 1 to 7 of 7
    Reputation: SteveF's Avatar
    Convert CL rotors to 6-bolt?
    Got a deal on a complete take-off set of XT brakes-only snag is they come with Centerloc rotors and I have 6 bolt hubs. I figured I could sell or trade them without too much trouble but looking at them, they look like the CL bit in the middle could be removed leaving a 6-both compatible rotor? They look sorta like this one, a randomly googled image:
    Anyone tried removing the center loc bit on something like this?
    Reputation: bvibert's Avatar
    Mar 2006
    That adapter is for using 6 bolt rotors on center lock hubs, the OP has the opposite problem.
    Reputation: ColinL's Avatar
    Feb 2012
    You can't use a centerlock rotor on a 6 bolt hub that I am aware. The spider probably mechanically prevents it.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by SteveF View Post
    Sell the CL rotor.
    Buy 6-bolt.
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    Sell the CL rotor.
    Buy 6-bolt.
    Heh, that does seem the simpler option eh? Thanks for the replies all--if I do attempt this conversion I will post results.
    Mar 2006
    Take some measurements first, I doubt it's even close.
  1. '06 Crossland able to convert to 15mm thru bolt?
    By IamDefiler in forum Wheels and Tires
    Last Post: 08-24-2013, 08:57 PM
  2. Convert centre lock to 6 bolt?
    By Tim Arnold in forum Brake Time
    Last Post: 06-04-2013, 05:52 AM
  3. Changing out 6 bolt rotors
    By millertm in forum 29er Components
    Last Post: 11-25-2012, 09:55 AM
  4. Are the new xtr ice tech rotors available in 6 bolt
    By dblvanos in forum Brake Time
    Last Post: 07-10-2011, 05:37 PM
  5. 2010 Easton Havocs convert to bolt-thru
    By Stonebreaker in forum Wheels and Tires
    Last Post: 07-02-2011, 09:14 PM
