Results 1 to 7 of 7
    Reputation: RazeR1970's Avatar
    compatibility question - xtr calipers
    My Anthem X 29er currently has Avid Elixir brakes with Clean Sweep X rotors. Front is 140mm and Rear 185mm (as stamped on the internal section of the Clean Sweep).
    I plan on changing the levers and calipers to XTR M985.
    Q1: Will the Clean Sweep Rotors be ok with the XTR calipers or will I need to change to Shimano rotors?
    Q2: If I go to Shimano rotors, which would you recommend?
    Riding or Drumming
    Reputation: funkydrum's Avatar
    Same question here. I have multiple wheel sets with Avid Cleansweep Rotors and would like to keep them with some XTR brakes.
    Tallboy
    Salsa El Mariachi SS
    Salsa Vaya
    Salsa Mukluk
    Surly Big Dummy
    Plays with tools
    Reputation: customfab's Avatar
    It's fine to use the Avid rotors. Although one of the better features of the XTR brakes is the ice tech rotors so you may want to give them a shot any way. The other thing I'll mention is that I've set up a few bikes with shimano brakes on Avid rotors and they didn't seam to have the same stopping power they did with Shimano rotors. Might have been a new vs. old issue or a heat treat difference between brands. It worked but I wouldn't say it was 100% ideal, more like 85.
    Quote Originally Posted by RazeR1970 View Post
    Front is 140mm? Are you sure?
    I've used Avid CSG3s with XTR 985 Race brakes. It works nicely. The CSG3 is the same stamping as the Avid XX, so I'm sure it will work. XTR centerlocks are just so darn heavy.
    Quote Originally Posted by Goran_injo View Post
    oops - reverse that
    140 on the rear
    185 on the front
    thanks team for the advice
    I think that I will go with new rotors (ice tech) to complete the picture.
  1. XTR trail or XTR race brakes...
    By bt in forum Brake Time
    Last Post: 01-28-2012, 03:07 PM
  2. Anyone try XT levers with saint calipers?
    By bkboom123 in forum Downhill - Freeride
    Last Post: 01-20-2012, 06:53 PM
  3. putting a normal steel axle into an M975 XTR rear hub?
    By Smiff in forum Wheels and Tires
    Last Post: 01-17-2012, 06:59 PM
  4. XTR Pedal Cleats for old school pedals
    By mmanuel09 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-17-2012, 04:38 PM
  5. XTR 970 and 10 speed ring question
    By therollex in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-15-2012, 08:31 PM
