Results 1 to 8 of 8
    Mar 2011
    New question here. Clydesdale wanting to upgrade promax 907 hydraulic brakes
    i bought a 2011 Gary Fisher Wahoo a couple months ago. That bike comes with promax 907 hydro brakes. while they're pretty good, they're not great, at least for me a 5'10'' 300lbs biker. i prefer to hydros, any recomendations?
    thanks in advance
    Reputation: mitzikatzi's Avatar
    Budget?
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Mar 2011
    $250
    Shimano SLX Disc Brakes M665 with a 185mm front rotor. You might need need rotors and adapters
    a little over budget but Avids come with everything you need to fit them
    Avid Elixir 5 Disc Brakes with G3CS 185mm Rotor
    or
    Avid Code 5 Disc Brakes With 160mm Rotor
    more All Mountain than XC but they will stop a big boy quick 160s might be enough
    185mm Codes
    edit adding links
    Mar 2011
    thanks for the advice mitzikatzi... i will certainly look into these
    Bike to the Bone...
    Reputation: rzozaya1969's Avatar
    Elixir 5 can be found below your budget. I would go with a 8" rotor in front, whatever at the rear.
    I had some Magura Louise BAT brakes before the Elixir 5 I recently installed. Honestly? I think the Louises are going to go back, but I'm still wanting to give the Elixirs a try. There is a problem (I think that it depends mostly with some frames only, not all) that makes the elixirs noisy and they sort of vibrate. I'm going to try another set of rotors than the original from Avid (Cleansweep 3), and see how they feel. I don't know how cheap/expensive the Louises are, but if within your budget I would look into them. There is a version that doesn't have the BAT thing, look into that.
    Shimano is also good.
    Reputation: Eville140's Avatar
    Pretty sure the Suntour fork has a 185mm rotor limit, so might want to check on that before ordering something.
    Bike to the Bone...
    Quote Originally Posted by Eville140
    Hey, good point! I didn't saw that...
