Results 1 to 3 of 3
    Clyde's Juicy Five upgrade - RX or K24?
    I've got an '09 Fuel EX 8 with 185mm Juicy Fives. I can't really complain about these Juicy's, but I would like a firmer brake lever return. The levers' return is a bit soft or mushy. I think I've ruled out Elixir CRs after trying them out, but am considering Formulas, RX or K24. I will likely have to order them sight unseen.
    -Do these Formulas have a firm lever return?
    -Is either better suited to a 245lb. trail rider?
    -Any other considerations?
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Have you tried bleeding the brakes?
    maybe the lever feel will improve ( and would be pretty cheap to try before upgrading)
    also at 245lb, I would recommend upgrading to a 203mm front rotor, if the forks allow it.
    look at any of the hope offerings? i am thinking since you are a big boy maybe v2 front and back or v2 front and m4 rear.
