Results 1 to 6 of 6
    Cleaning v-brakes (rims and pads)?
    What's the best way to clean the rim and pads for v-brakes?
    I was away from my MTB for about a year and before riding it I cleaned the rims using iso alcohol. I'm getting a howling/honking when I brake hard with the front brake. The braking also stutters slightly. It uses KoolStop pads. I wonder if the pads are dirty, but I don't know the best way to clean them. Is sanding/filing them appropriate? I cleaned the rims on my wife's bike the same way and they're super quiet and smooth, but it uses different v-brakes.
    Thanks.
    Huckin' trails
    Reputation: David C's Avatar
    Quote Originally Posted by jsilva View Post
    Thanks.
    Wipe off the pads, then clean with alcohol. If they are too much solid dirt on them, slightly filed them. They will get dirty again anyway, so wiping off is the best way after cleaning and filing... I run v-brake all winter long and simply rinse the rims and pads with water and no problem.
    David
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    Reputation: mitzikatzi's Avatar
    "clean" rims can cause noisey brakes. You need to re bed the brakes which puts a layer of brake material onto the rims. Same reason wet rims make a noise.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Thanks.
    try to clean it with soft water with shampoo before putting an alcohol!!!
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Do the pads need toeing in?
    Raised in a Chicken-Coop by Chickens
    Huckin' trails
    Quote Originally Posted by Sheepo5669 View Post
    Yep, a bit. A simple ride should bed them in again.
    David
  1. cleaning pads
    By b-kul in forum Apparel and Protection
    Last Post: 09-29-2011, 04:27 PM
  2. What pads for ceramic rims? (v-brakes)
    By Rasper in forum Brake Time
    Last Post: 03-29-2010, 08:19 PM
  3. v-brakes pads for ceramic rims
    By karjak in forum Brake Time
    Last Post: 11-23-2007, 07:31 PM
  4. Ceramic coated rims + v-brakes...regular pads or no?
    By curtlo-dork in forum Brake Time
    Last Post: 07-28-2007, 09:16 PM
  5. Cleaning Brake Pads
    By doanster in forum Beginner's Corner
    Last Post: 05-09-2004, 08:04 PM
