    Enthusiast
    Reputation: JonathanGennick's Avatar
    Is Clean Streak ok on brake pads?
    Was it a bad idea for me to clean my brake pads using White Lightning's Clean Streak? Braking power seems diminished. I'm a bit worried that I may have just made a $40 blunder.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Since when do pads cost 40 bucks?
    You'll probably need to rebed them.
    I hate using that stuff around brakes. It makes them squeal until you ride it for a while.
    Enthusiast
    Front and rear.
    I actually did all the cleaning to get rid of a squeal. So far, so good, though I've only been around the neighborhood one time.
    The other thing that I did was to swap the pads around. My LBS had put one each of organic and metal on both front and rear. I changed things so that the two organic pads are in the back, and the two metal pads are in the front. I also cleaned and lightly sanded the pads.
    The shuddering seems to be gone, and I hope it stays gone. I hope the noise stays gone too.
    A set of front & rears cost around $40.
    try cleaning them with rubbing alchohol. Some folks around here have luck "cooking" the pads to burn off any goo in them...I've never tried it.
