Results 1 to 15 of 15
    29er for life!!
    Reputation: NCMt.Biker's Avatar
    May 2010
    Clean roters with??
    Im sure im beating a dead horse but what do you guy's use to clean your roter's with???thanks
    staike
    Reputation: staikeinthahood's Avatar
    Disc brake/rotor cleaner. Buy it cheap in any autostore.
    Quote Originally Posted by NCMt.Biker View Post
    Soap and water then a water rinse.....then isopropyl alcohol.
    bi-winning
    Reputation: rkj__'s Avatar
    Typically, I wipe them clean with my brake pads. What are you trying to clean off of them?
    29er for life!!
    May 2010
    I just ment a routine cleaning of them,there's nothing on them right at the moment,
    staike
    Quote Originally Posted by rkj__ View Post
    Take a clean rag and wipe off your rotors and you will realise it's way more shit on it than you thought. Do it with some disc brake cleaner after that and see how much more you can get off it.
    OP: Do the same with your pads. Clean them with disc cleaner and give them a round with some sanding paper as well. That + bleeding the brakes and lubing the pistons will make the brakes feel like new again.
    Reputation: SeaBass_'s Avatar
    I do a quick wipe with denatured alcohol
    bi-winning
    Quote Originally Posted by staikeinthahood View Post
    Sure, you can wipe "shit" off of them, but it is absolutely unnecessary.
    I do not include cleaning the braking surface as routine maintenance on any vehicle, bicycle, motorcycle, car, truck, etc...
    Aug 2010
    Just replaced the pads on my bike. Hayes instructions say use isopropyl alcohol not brake cleaner.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    If you are putting new pads on, then clean the discs. No need to wipe them down with anything for general maintenance.
    A dirty brake is a happy brake!!
    If the pads were properly bedded in, you won't gain any performance by cleaning the rotors.
    **edit**
    I am referring to regular riding, brake dust doesn't need to be wiped off. If you are riding in the swamp etc, or commuting in salty slushy snow all the time, then they may need to be cleaned for sure!
    Quote Originally Posted by Shark View Post
    This is where you are wrong....a brake heavily fouled with mud, or salt, or even dust...often has quite a bit more DRAG than a clean brake...
    Remember lack of drag is also a measure of performance.
    Reputation: mtbnozpikr's Avatar
    Quote Originally Posted by jeffscott View Post
    +1 for the isopropyl alcohol.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
    More Torque
    Reputation: Diesel~'s Avatar
    Quote Originally Posted by SeaBass_ View Post
    Same; using a clean rag.
    -D
    Feb 2006
    If they are that bad, then I agree a bit of water & scrubbing may be in order, but many folks have the misconception that they need to wipe the "brake dust" off the rotors with brake cleaner or alcohol after every ride. That is simply not true.
    Good point.
    2012 Intense M9
    2008 Look 595
